Bare Wood To Old Paint Transition? - Painting - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 11:15 PM   #1
Bare wood to old paint transition?
I'm prepping the exterior of a small house for paint, and spent the entire day scraping off the old flaking paint. This house was painted once in the 1980s. Its T-111 siding and in rough shape.
The lower half of the wall is extremely flakey, while the upper half is still in decent shape, no flakes whatsoever. The flake areas I scraped down to bare wood, but I don't want to scrape the upper areas if I don't really need to.
So my question is this, will I be able to primer/paint/paint over that entire wall without seeing the transition from bare wood to old paint?
I will try and post a picture tonight to give you a better idea...
Thanks in advance everyone!
lbc970 is offline   Reply With Quote
Old 07-20-2013, 11:33 PM   #2
There is the best picture I could get in the dark. Gives ya a bit of an idea anyways...
Old 07-21-2013, 08:00 AM   #3
Rewards Points: 14,020
Going to need to sand it to feather it in.
If the wood rotted, it's time for plan B and replace it.
Old 07-21-2013, 08:13 AM   #4
A Little Of Everything
Rewards Points: 1,364
That vertical siding is cheap crap. But it's what you've got, so you get to deal with it...
If it's not rotted on the bottom, sand it lightly to transition in to where there's still paint. Then prime it with oil-based primer, and top-coat with 2 coats of good latex paint.
DrHicks is offline   Reply With Quote
Old 07-21-2013, 08:17 AM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
This.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-21-2013, 08:24 AM   #6
Excellent! That was my plan, just wanted to be sure. Thanks guys
wood deform - does paint help or not? jackwashere Building & Construction 1 05-17-2013 03:51 PM
wood paint for fireplace box pberm1962 Painting 3 05-02-2013 08:22 PM
Best wood species for bare clapboard siding pipeorgan89 Building & Construction 2 10-16-2010 09:46 PM
Priming Interior Wood Doors Lovegasoline Painting 6 09-12-2009 03:48 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
