Bad Wallpaper Day! - Painting - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 03:49 PM   #1
Question
Bad wallpaper day!
Greetings, all! Got a real problem on my hands: my "new" 1972 home has badly applied, textured wallpaper on the living room walls that the seller painted over with white latex. If the texture weren't bad enough, the ding dong over lapped every seam which is terribly visable and the room has a southern exposure with tons of light streaming in, showing every imperfection. The room is 16 x 20. We tried many means to remove the paper but only gouged the walls. Is there a way to remedy this situation without replacing the drywall? Any/all help would be greatly appreciated.
balmore58 is offline   Reply With Quote
Old 02-01-2011, 04:18 PM   #2
I've never ran into this before but found this discussion that may help. They are talking about wall paper painted over plaster walls maybe you can get tips from here.
http://ths.gardenweb.com//forums/loa...923055.html?10
Shipp's Painting LLC
http://www.paintingkokomoindiana.com
Shipps Painting is offline   Reply With Quote
Old 02-02-2011, 12:28 AM   #3
Super Master Painter
Ole34's Avatar
go to homedepot and get whats called a PAPER TIGER and a GARDEN PUMP SPRAYER...........scratch the walls up with the paper tiger then wet them with the pump sprayer using plain ole water.......LET THE WATER SOAK IN !!!............ LET THE WATER SOAK IN!!!..............LET THE WATER SOAK IN!!!................ ok after the water has soaked in start to remove it with a spakle knife ...............the key here is to SOAK THE PAPER. i tell people this all the time and they dont listen then i go over and show them how its done.......................SOAK THE PAPER
8 out of 10 times it will come right off................
Ole34 is offline   Reply With Quote
Old 02-02-2011, 11:28 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
You forgot to mention soaking the paper.
Old 02-02-2011, 01:17 PM   #5
Ole34's Avatar
no matter how many times i mention it people never listen....they get inpatient and start digging at the walls then come back and blame me for bad advice.................lol LET THE WATER SOAK IN !!!
Old 02-02-2011, 03:53 PM   #6
You I've found that a scraper a vinegar works very well in the removal process, a technique I discovered when the box store closed on me
Alcarte is offline   Reply With Quote
Old 02-02-2011, 04:55 PM   #7
Professional Painter
Texture over / Joint Compound over
I use to not believe in this, but what you can do is to texture over it, or fill the holes with joint compound. I just did this recently on a job and it looked awesome. A friend of mine did this and textured over it in his bathroom. Looked fantastic. Contact me and we can talk more about this...
mattroefer is offline   Reply With Quote
Old 02-02-2011, 05:09 PM   #8
Ole34's Avatar
ok lets break this down to solutions for your problem
1-remove the wallpaper: more labor intensive but will provide the best finish afterwards...highly recommended
2-oil prime the wallpaper then skim coat the entire area then sand,prime,caulk,paint.....VERY labor intensive but a better finish
3- prime/patch and paint over wallpaper: easy fix, less expensive and not much labor involved.......LOW END FINISH, mostly seen in rental properties
Old 02-02-2011, 07:28 PM   #9
Rewards Points: 258
Hey balmore,
Am I the only one here that noticed no one has suggested a wall paper steamer? Gas is best but electric will do. You can rent them at any well stocked rent it shop. The steamer will make short work of that paint and the wall paper doesn't stand a chance. No paper tiger, no vinegar, no sweat. If you want to do it like a professional then use the steam, if you want to do it like a homeowner use the other Home Depot suggestions.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 02-02-2011, 07:32 PM   #10
Ole34's Avatar
lol..........steamers are for homeowners, be there all day steaming wallpaper off ...........ill scratch and entire room up then soak it then with in 20 mins i will pull it off in SHEETS
Old 02-02-2011, 08:07 PM   #11
Rewards Points: 258
Hey Jack,
Where in southern Michigan? Or would rather not say?
Best of Luck
Steve
Old 02-02-2011, 08:08 PM   #12
Experienced
Jackofall1's Avatar
Hey Jack,
That would be Warren
Mark
Old 02-02-2011, 08:25 PM   #13
Rewards Points: 258
I'm way out in Highland, not far from Milford.
Best of Luck
Steve
Old 02-03-2011, 10:24 PM   #14
Oh you Home Depot suggesters. I am going to try and point my microwave at the wallpaper in my living room and see how it works.
Old 02-04-2011, 01:14 AM   #15
Ole34's Avatar
double post , sorry
painting and wallpaper residue jayoshi Painting 1 09-13-2009 05:03 PM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
Removing Wallpaper fcamargo6thave Painting 17 04-27-2009 02:59 AM
How many layers of wallpaper is too many? dumbunusedid Painting 14 07-19-2008 04:48 AM
This wallpaper glue is stubborn! proofer Painting 7 03-07-2008 05:53 PM
