Bad Finishing Job - Painted W/semi Gloss - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 05:49 PM   #1
Bad finishing job - painted w/semi gloss
My contractor is pretty good with a lot of things but dry wall isn't one of them. He left my new bathroom walls in bad shape. It was totally gutted bathroom, with all new dry wall. I assumed the finishing job was finished as he left it that way and said was ready for painting.
Naturally, I wanted semi gloss as its a bathroom. There is a window opposite one wall. The paint is a deep rich red color. Every little defect and rough surface on that wall shines! Looks terrible after a prime coat and two coats of semi gloss.
What can I do to get it smooth now that it has three layers of paint on it? Some areas look really rough like he did not even use a skim coat. I'm so dissatisfied with this as I paid a small fortune for this bathroom.
I'm not saying anything to him about it. Just trying to fix it myself.
Donna17 is offline   Reply With Quote
Old 07-08-2014, 06:03 PM   #2
DIY staff
Rewards Points: 7,174
You used semi-gloss on the walls--that is unusual--egg shell is usually the most gloss that is used on a wall---
Typically, on new work, the walls are primed---then defects are spotted--and fixed--those patches are then primed---the walls lightly sanded--
That is when the top coats go on.
You aren't an experienced professional painter---so I'll bet you didn't know that the new work needed so much prep work---
I have had issues with homeowners attempting to paint my new drywall work----so now, the price includes priming--so we can catch and correct the minor flaws before the painter shows up.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Donna17 (07-09-2014), Gymschu (07-08-2014)
Old 07-08-2014, 08:16 PM   #3
The primer was white flat paint which didn't show grainy bad finishing.
I'd like to move this thread to the paint area because I need advice. I already know what I did wrong.
Old 07-08-2014, 08:29 PM   #4
Rewards Points: 14,014
If you where shooting for a deep red color the primer also should have been tinted gray or at least to 50% of the color you where going for.
It may take about 5 coats of real paint to get it so the flaws do not show.
Did you run your hand over the wall to see if you can feel these flaws.
100% sure it not the way it being painted?
Cheap rollers, to low a nap roller cover, cheap paint, improper use of the roller can all cause issues.
Where not there to see it, no one here knows if you have ever painted before or what your using so some questions needed to be asked and some pictures would be great.
Old 07-08-2014, 09:04 PM   #5
DIY staff
I moved this to 'painting' for you--
Old 07-08-2014, 09:12 PM   #6
Gymschu's Avatar
Rewards Points: 934
Do a search on "skim coating" on here. That's about your only option at this point if you really want to correct all of those flaws. Personally, if a contractor messed it all up like that, it's his responsibility to fix it. You really should contact him. He likely hired a drywall subcontractor and may be unaware of the poor workmanship.
Oops, I see on your other thread that you want to avoid having to skim coat. In that case, you should get a random orbital sander with 80 grit sandpaper and knock all the high spots down. It can be fairly aggressive so be careful that you don't cause even more damage. You will still have to spackle/mud low spots and areas the sander may damage.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 07-09-2014, 03:01 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
first major mistake
Old 07-09-2014, 06:06 AM   #8
cj133's Avatar
Rewards Points: 318
Eh,
While I'm new to this I don't know how much of a mistake semi-gloss is.
I've been using satin on both my walls and ceilings after skimcoating terrible 120-150yr old plaster. There are imperfections, but I do my best.
I believe our bathroom is done in what Valspar calls "soft-gloss" and it's just a hair below semi-gloss and is their standard bathroom / kitchen paint.
Honestly, if it's all new drywall I'd expect to be able to paint it in semi-gloss if not high-gloss and see few imperfections. The point of my response is I feel choosing semi-gloss wasn't necessarily a mistake, whoever did the tape and mudding was the mistake.
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
The Following User Says Thank You to cj133 For This Useful Post:
Old 07-09-2014, 09:37 AM   #9
I used a piece of fine sanding paper (because it was all I had) and sanded it and then wiped off with damp cloth. I can see grainy spots but when i run my hand over it, it feels somewhat smoother. Maybe rather than skimming yet, I'll get a better sanding block and sand it a little more then try re-painting. I only had two coats of the red. With that window light falling on that wall, I'm wondering if that one wall (which starts from about 5 feet from floor because tiled under that) should be finished with satin instead of semi gloss but guess I won't know till I try sanding and another coat.
Old 07-09-2014, 09:39 AM   #10
Originally Posted by chrisn View Post
first major mistake
I have read they recommend that in bathrooms where you have high moisture from steam etc. This wall is right next to shower.
Old 07-09-2014, 09:44 AM   #11
cj133's Avatar
Rewards Points: 318
After sanding use a damp grout sponge and rub the compound. You'll find it slightly softens and rubs it smooth. If you try too much you can even completely remove the joint compound.
This only works on unpainted compound so if it's painted don't bother.
I often do this without sanding at all.
Old 07-09-2014, 12:30 PM   #12
Rewards Points: 4,796
Semi gloss is fine in a bathroom theoretically - it's mostly aesthetics, and protects as good or better than eggshell. But to the same extent, it will show flaws as much or more than eggshell. I personally don't like glossy paint, but if someone asks to put it in their bathroom I would certainly do it. I'd advise that the walls need to be perfect or nearly so, though.
What you probably need to do is give all the walls a light sanding, then patch the roughest areas and then skim coat the entire surface. I prefer the following technique (although I would never need 3 layers as they state. I would do 1 or rarely 2, you might need 2 but I fail to see how 3 would ever be necessary unless you are really horrible at this.)
http://www.familyhandyman.com/drywal...kim-coat-walls
Then prime with a good quality drywall sealer tinted to the correct shade of gray recommended by the paint manufacturer for your shade of red (if using Sherwin Williams, the correct shade of gray is specified in a code on the actual paint sample chip.) If you can't put that much tint in the primer/sealer, then you will need a separate color primer coat, or be resigned to possibly an extra coat of finish paint. Gray color primer isn't required, just preferred.
The days of 5 coat coverage with deep or bright reds is gone. If you have to put on that many coats, you're simply using cheap paint. If using a highly opaque paint such as Aura, you shouldn't need more than 2 coats. No high quality paint should need more than 3 coats, ever.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
cj133 (07-09-2014)
Old 07-09-2014, 12:36 PM   #13
By the way, I do understand the recommendation for more glossy paint in high humidity areas. Having said that, this pales in comparison to reducing the cause of the humidity to begin with, which usually means lack of ventilation. The gloss of the paint simply can't make up for a water issue, although it helps a small amount. It's far more important to have a high quality bathroom fan (compare CFMs) blowing through a good, open duct with no tight bends or kinks, than it is to use semi-gloss instead of egghsell paint.
http://www.homedepot.com/c/bath_fans_HT_BG_BA
People know little about bath fans - that's why builders use the cheapest fans they can install - 50 CFM at best - and don't always install the ducting correctly either. Building codes in some places don't even require a fan when the bathroom has a window, which is ridiculous - maybe worked before air conditioning, but not today.
cj133 (07-09-2014)
Old 07-09-2014, 12:41 PM   #14
cj133's Avatar
Rewards Points: 318
This is the main reason I went through hell installing a "fart fan" in our main bathroom which has an almost flat roof, was to get rid of moisture from showers. I couldn't care less about smell, that doesn't harm the house.
The previous owner had painted the bathroom in flat paint and there was no fan. After installing an 80 CFM Panasonic fan which I think was around $200 + all of the stuff to go with it our mirrors don't even fog up after a long shower. I was tempted to buy the 110 CFM version but it didn't seem necessary in our bathroom, also I think Panasonic's ratings are more realistic than the cheap units.
That, combined with soft-gloss paint and we no loner have any issues.
As you know, I hate flat paint and love gloss even with imperfections.
Semi Gloss in White and Spackle Spots have NO Gloss - What's happening here? 777funk Painting 41 08-19-2013 09:36 PM
water base polycrylic over oil high gloss twenger26 Painting 4 07-18-2013 08:39 AM
painted over high gloss paint... next steps? alex12345 Painting 5 01-08-2013 02:55 AM
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 06:46 PM
Gloss Piano Black wood Aquarium stand advice markus09 Painting 8 02-29-2008 05:27 PM
