B Moore Aura Or Regal Select Interior Semigloss? - Painting - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 03:30 PM   #1
Rav
Rewards Points: 552
B Moore Aura or Regal Select interior semigloss?
I'm about to paint some interior window trim, in semigloss. I'm not changing the color (Ben Moore 926-seashell), it's just that the existing paint is a little beat up and I did some re-caulking of some gaps. I want to be able to apply just one coat if at all possible. I have some leftover Ben from a previous project, but I wasn't too happy with how that turned out, so I'm trying to decide between Aura and Regal Select. I've read that you have to work fast with Aura because it dries quickly, so would Regal Select be a better option? Thanks.
Rav is online now   Reply With Quote
Old 02-05-2014, 05:09 PM   #2
Rewards Points: 351
For trim I'd use BM Advance or Satin Impervo myself.
info2x is offline   Reply With Quote
Old 02-05-2014, 05:56 PM   #3
Painting Contractor
Rewards Points: 85
I think you would be much happier with the Regal Select. I paint professionally, and I struggle with Aura. The only Aura I use Is their Spa and Bath for bathroom walls.
VAProPainter is offline   Reply With Quote
The Following User Says Thank You to VAProPainter For This Useful Post:
Rav (02-05-2014)
Old 02-05-2014, 06:41 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Put me down for the Regal.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 02-05-2014, 06:57 PM   #5
Rewards Points: 5,974
I would vote for the Advance but am curious why you would select Regal over the Advance.
Old 02-06-2014, 03:07 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 140
way easier to work with?
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (02-06-2014)
Old 02-07-2014, 09:11 PM   #7
Painting Contractor CT
Rewards Points: 77
Post
Both are great paints, Aura is slightly thicker paint...good luck!
KD PAINTING is offline   Reply With Quote
Is Aura or Regal Select significantly better than Ben? Rav Painting 6 08-17-2013 12:09 AM
Benjamin Moore Aura - Blotchy Even After 4 Coats BobSmitt Painting 13 09-06-2011 06:20 PM
Has anyone used Ben Moore REGAL SELECT exterior paint? staceyneil Painting 3 08-10-2011 12:00 AM
Need Opinions on Benjamin Moore Aura Paint dorothyolive Painting 11 10-14-2010 10:21 PM
Sherwin Williams Duration vs Benjamin Moore Aura zfarsh Painting 18 06-02-2010 09:38 PM
