Automatic Roller - Painting - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 10:18 PM   #1
Automatic Roller
Hi All,
Please give me your thoughts on automatic paint rollers. Do they really make the overall job easier?
Best,
Bob
Bob Guercio is offline   Reply With Quote
Old 02-25-2011, 10:27 PM   #2
I have never used one in all my years, and I've never seen another professional use one either. If they worked, the people who put extra money in their pocket when productivity increases would be lining up to buy them.
Old 02-25-2011, 10:33 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
This is true. The extra time and agrevation cleaning those far exceed the benefits they produce. If time is the critical factor then nothing beats a sprayer even with someone backrolling.
Old 02-26-2011, 04:24 AM   #4
I had thought about the cleanup and all the extra work.
Regarding spraying, I have two questions.
I presume that backrolling means following the spraying operation with a roller in order to clean up dripping paint? Can one person perform both functions, spraying and backrolling?
Secondly, is it very difficult to spray paint a ceiling? It seems that it would be more difficult going against gravity.
Thanks again,
Bob
Old 02-26-2011, 04:42 AM   #5
Backrolling will give the substrate a look of a traditional cut and roll. One person could perform both functions. I like to have two people working together so there are no problems with the paint setting up on you before you can backroll. Ceilings are no problem as the spray machine should have plenty of power.
Two other things that are critical are masking and cleaning.First make sure that anything that you don't want painted are masked off with plastic and tape. Be careful that the tape is applied tightly as the paint will find it's way behind it otherwise. Second vacuum everything completely. Especially if it's new construction. That means electrical boxes, between drywall and floor, etc. If you have a dirty area you will put the dirt into your finish and will have a mess to clean that won't be fun.
kboyz is offline   Reply With Quote
The Following User Says Thank You to kboyz For This Useful Post:
Bob Guercio (02-26-2011)
Old 02-26-2011, 05:08 AM   #6
I gave the steps in the wrong order. Clean first, mask next. Use a quality painters tape that will come off easily and without damaging anything.
Old 02-26-2011, 07:48 AM   #7
Gymschu's Avatar
Rewards Points: 668
We have timed the power roller vs. a man with a regular roller. Believe it or not, the man with a traditional roller system wins quite handily if he knows what he's doing.
Old 03-12-2012, 07:34 PM   #8
Another professional painter here: I use good-old-fashioned manual lamb skin rollers. Sounds like that's the majority opinion in this thread.
enos is offline   Reply With Quote
Old 03-13-2012, 03:59 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 316
[quote=enos;876315]Another professional painter here: I use good-old-fashioned manual lamb skin rollers. Sounds like that's the majority opinion in this thread.[/quote]
which has been dead for over a year
chrisn is online now   Reply With Quote
Old 03-26-2012, 02:07 PM   #10
And yet I seem to have raised the dead.
Old 03-26-2012, 04:00 PM   #11
chrisn's Avatar
Rewards Points: 316
yes,yes, you did
What am I Doing Wrong Here (Roller Marks, pics) dimswits Painting 13 08-01-2016 05:33 AM
Paint interior with spray gun or Wagner power roller or other? AliceT24 Painting 4 02-18-2011 01:26 PM
Flashing --> how does it occur and how to prevent it gramps416 Painting 5 05-26-2010 11:11 PM
Roller advice/Surface Issues? gmhut Painting 6 03-10-2010 08:32 AM
Better way of connecting cable loop to roller chain? deleyd General DIY Discussions 1 06-30-2009 10:52 PM
