Applying Drywall Compound To Sheetrock - Painting - DIY Chatroom Home Improvement Forum
Old 04-26-2008, 02:55 PM   #1
Rewards Points: 150
Question
I've been of the boards for a while now, but a while back, I posted a question regarding applying drywall compound over sheet rock that had been covered in wallpaper. I'm hand-troweling it, trying to achieve a bit of a Venetian plaster effect. I just finished a hallway that is not often used and not brightly lit, so I don't think my boo-boos will be that noticeable.
However, having actually gotten into the process, some other questions have arisen. [I've opted to use the pre-mixed compound.]
Do I want to have a fairly moist mixture? Or does that depend on the weather conditions?
Should I start troweling at the top by the ceiling and work down, or at the bottom by the molding and work up?
What's the best technique to use when moving down the wall from a finished area to a new spot.
Do I move the trowel in more or less straight lines or in great big arcs?
Sorry to have posted so much at once.
shapeshifter is offline   Reply With Quote
Old 04-27-2008, 12:44 AM   #2
Pro Painter
Do I want to have a fairly moist mixture? In your situation, yes. You mentioned venetian plaster, but it sounds like it's just coming out that way. If you were to go for real venetian plaster, there are some short, dry strokes involved.
Or does that depend on the weather conditions? Weather conditions will determine the amount of working time. If there's little humidity then the working time will be less. More humidity means more working time. Having a "wet" mix will also increase working time.
I could guess at these, but why don't you check out a drywall or plaster forum. They specialize in this area and are more able to steer you in the right direction..........
joewho is offline   Reply With Quote
Old 04-27-2008, 01:29 PM   #3
Rewards Points: 150
Talking
Sorry Joe, if you posted a reply it did not come through.
Day 2: On yesterday's project, I went back with a thinner mix and covered the spots that were missed, leveled out the craters and splotches and added a little texture that I can burnish tomorrow.
On today's new portion, we again used a thinner mix and troweled on a very thin coat. Tomorrow, I will go back over and even things out and add some of the texture that can be burnished.
It really isn't that complicated, just a little labor intensive but I think I like what it will be after it's primed and painted.
Old 04-27-2008, 09:06 PM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 896
If you could take a few pictures and post them that would be great.
Sir MixAlot is offline   Reply With Quote
Old 04-27-2008, 09:34 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
Did you prime the wall covering before applying the mud?
slickshift is offline   Reply With Quote
Old 04-27-2008, 10:15 PM   #6
Rewards Points: 150
Unhappy
Noooo I didn't. Isn't drywall mud usually applied to the unprimed drywall? We will prime before we paint, however.
Old 04-28-2008, 07:58 AM   #7
slickshift's Avatar
Had the wall paper been removed?
All the adhesive also?
For new construction mud is usually applied over uncoated sheetrock
For repairs or things like skim coating after wall covering removal, it's best to prime first
Those are special circumstances
Old 04-28-2008, 10:21 AM   #8
Rewards Points: 150
Angry
Ewwwww
Yes we removed all the wallpaper and cleaned off the remaining adhesive. Looks like they only used the adhesive at the seams.
Old 04-28-2008, 10:38 AM   #9
slickshift's Avatar
Stripped and real clean you should be OK
But really, for anyone else reading this, or for yourself the next time you do this (...if there is a next time), it's best to sand and prime something like this before mudding
Whether it's just small repairs or a full skim/texture
Good luck with your plaster effect
Old 04-29-2008, 03:42 AM   #10
Pro Painter
The answers are in your quote. It wouldn't post that way, so I had to ........ for it to post.
Is all purpose drywall compound not strong enough? yummy mummy Building & Construction 3 04-23-2008 12:35 PM
Applying joint compound to corners DK75 Remodeling 15 04-17-2008 11:31 PM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 04:00 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 08:22 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
