Applying Deck Stain - Painting - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 11:59 AM   #1
Applying deck stain
Can I use a pump sprayer with a semi-solid stain? I've used them with translucent before but not sure if a semi solid would work. Thanks
jamjr74 is offline   Reply With Quote
Old 05-18-2012, 03:03 PM   #2
Rewards Points: 150
You have to read the can, some say not to spray.
CaptRandy is offline   Reply With Quote
The Following User Says Thank You to CaptRandy For This Useful Post:
Mr. Paint (05-18-2012)
Old 05-18-2012, 04:13 PM   #3
Mr. Paint's Avatar
Yes you can if it is labeled for such. You will still need someone to back-brush behind you to even-out the application.
Mr. Paint is offline   Reply With Quote
Removing stain from deck machouinard Painting 20 09-08-2011 09:12 PM
Deck Stain and Sealer swoolly Flooring 1 08-26-2010 05:55 AM
What is the best way to apply stain to a deck? flashme18 Painting 4 04-24-2008 09:23 PM
Deck Stain jte1130 General DIY Discussions 1 04-07-2008 02:04 PM
