Appliance Epoxy Spray Paint - Will It Stop Rust? - Painting - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 08:29 PM   #1
Rewards Points: 1,656
Appliance Epoxy Spray Paint - will it stop rust?
Not sure if this is "Painting" or "Appliance" forum but here goes.
I have a washing machine that is developing a few rust spots. A few on the underside and edge of the lid, and two inside the metal "tub".
I was thinking, if I clean the rust as best I could, can I coat something on top of these rusty spots and prevent further rust? I was looking at this product:
It does say it's "ultra-hard, moisture resistance enamel" but obviously is designed for the outside shell of washers, dryers, fridge etc...
Any chance this may work? If not, any other recommendation?
Thanks in advance.
miamicuse is online now   Reply With Quote
Old 04-22-2013, 08:38 PM   #2
Rewards Points: 14,312
I wire brush the rust, rusty metal primer, then use that as a top coat.
http://rustoleum.com/CBGProduct.asp?pid=41
Mask off what you do not want painted.
Old 04-23-2013, 01:32 AM   #3
Too Short? Cut it Again!
Self-etching rust inhibiting metal primer on brushed rust spots with corrosion removed. Or you could try a rust converter product.
Follow with the epoxy appliance paint. It will buy you some time.
Old 04-23-2013, 08:19 AM   #4
Rewards Points: 394
Most of these products were originally powder coated (baked on finish). The spray can exhibited should recommend a primer under it. Also, appliance paints are generally for the OUTSIDE of the appliance, and are not used for immersion (water) service.
Will22 is offline   Reply With Quote
Old 04-23-2013, 08:57 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
Having been through that a couple of times.....in my experience...when your getting rust like that...the machine is most likely old and worn out....time to replace.
If your budget will not allow that....
I would first suggest filling up the tub with water and pouring in a gal of vinegar....let it sit for a day or two or three...then run a rinse cycle...that will get rid of most of the rust....especially the rust you can't see. Then paint....
Just understand that it's temporary measure....I got about another year out of mine before it bit the big one....
protecting spray paint on laminate furniture anderson.beth Painting 3 01-10-2013 09:48 PM
Spray paint accident help the_M_man Painting 19 07-22-2011 02:14 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
spray paint dry time question joeyboy Painting 12 01-15-2010 05:21 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
