Anything To Keep In Mind With Painting Textured Walls? - Painting - DIY Chatroom Home Improvement Forum
Old 10-16-2007, 11:55 PM   #1
Ummmm...
Shpigford's Avatar
Anything to keep in mind with painting textured walls?
Unfortunately every wall in our home will have a texture (see pic below)
Though our texture isn't as significant as that picture, it's the same general look.
Will that make painting things more difficult (ie. needing to put more paint on) or easier (ie. not showing light patches on one coat of paint)?
Any other things to keep in mind with painting this sort of wall?
Shpigford is offline   Reply With Quote
Old 10-17-2007, 10:02 AM   #2
Pro Painter
The main thing is holidays. If you use a 3/4 roller be very thorough, go side to side and up and down. Coat a wall to your satisfaction, let it dry, look for the holidays. This will give you a better idea of how the holidays will appear.
Use a "thin" paint to get better coverage.
joewho is offline   Reply With Quote
Old 10-17-2007, 10:06 AM   #3
Ummmm...
Shpigford's Avatar
Eh, what are "holidays"...in relation to painting?
Old 10-17-2007, 08:59 PM   #4
I know it sounds crazy ! but holidays are areas you have missed when rolling or brushing the paint on, depending on the existing colour and the new colour sometimes they are hard to spot,also it depends on the lighting conditions.
Regards D/B
davidandbess is offline   Reply With Quote
Old 10-17-2007, 11:22 PM   #5
Paint/Faux Artisan
Da Vinci's Avatar
Also, use a good 1/2" thick roller. It's actually easier to get a nice look with texture than it is with a perfectly smooth wall- you'll do great...
Bob
Bay Area Painting COntractor
Da Vinci is offline   Reply With Quote
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
Painting walls different color at an outside corner J187 Painting 8 08-16-2006 07:16 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 05:33 PM
painting walls w/oak trim THEBIGPUNN Painting 3 04-25-2006 02:28 PM
painting 18' walls sedona48 Painting 1 02-07-2004 06:18 PM
