Anyone Used Sander Deglosser On Trim Before Painting? - Painting - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 01:20 PM   #1
Anyone used Sander Deglosser on trim before painting?
Or a similar product?
We are painting all the ugly plain builder-grade trim in our house, and it's all currently coated with varnish. In an attempt to avoid crazy amounts of sanding, I wanted to try this product I saw at Home Depot - KleanStrips's Liquid Sander Deglosser. The reviews on the HD website are very good - seems to work really well and really quickly for everyone.
Just curious if anyone here has used this prior to painting trim or any other woodwork.
Thanks!
sosee11 is offline   Reply With Quote
Old 03-21-2013, 05:19 PM   #2
Gymschu's Avatar
Rewards Points: 240
Recent similar thread: liquid sandpaper
If it's varnished, it's much better to sand with REAL sandpaper. It is much more effective at giving your bonding primer something to stick to. Just be sure to remove all the dust before priming.
Old 03-21-2013, 05:24 PM   #3
cdaniels's Avatar
De-glossers don't work well enough by themselves.You need to sand first to give the next coat a grip.It doesn't take "crazy sanding" just a light scuff with a sanding sponge will work fine.Wipe it down after sanding with deglosser then since you said it was varnished apply a quality bonding primer. Let it dry according to label recommendation and you're ready for paint.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 03-21-2013, 08:26 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Some of the acrylic bonding primers ( Like zin 123) say not to use deglossers. Oil to oil I used to use Wilbond all the time.
That will burn some extra brain cells off..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (03-21-2013)
Old 03-22-2013, 08:05 AM   #5
Rewards Points: 2,040
oh no!
I've been using deglosser on my trim, but the finish was worn, so hope I'm ok.
Startingover is offline   Reply With Quote
Old 03-22-2013, 08:08 AM   #6
The info on the paint/ primer can is good to read. It says stuff.
Old 03-25-2013, 02:24 PM   #7
Surely this snark wasn't intended for me, right?
Is a light scuffing truly all it takes? As in, I don't need to sand down to actual wood? We have a really good primer from BM that we'll be using, but we also have some Zinsser as well that we used in our basement recently on some bare wood.
Everything I've read re: painting wood trim isn't very descriptive in terms of how much sanding actually needs to be done. I was using a 180 grit sanding block I think and the wood still felt smooth to me so I was worried that I wasn't "scuffing enough" - hence the idea bout the deglosser.
Old 03-25-2013, 04:49 PM   #8
cdaniels's Avatar
The 180 should be fine.I would use 150 but all you need is to dull it and the 180 will do that.Just a light scuff will suffice.If you're using a latex bonding primer,don't use deglosser to clean it.Brush is right.
Old 03-25-2013, 04:53 PM   #9
cdaniels's Avatar
Originally Posted by Startingover View Post
oh no!
You will be OK.Just make sure to read the label and do what it says.Deglossers usually have a window for recoat time.
Old 03-25-2013, 04:56 PM   #10
I do sometimes use the no rinse TSP substitute to clean and etch. Not quite as harsh as a deglosser- but it can help.
deglossers have lots of solvents that will melt into an oil finish, but might not into a waterborne. They could actually wrinkle the prime.
I'm sure new ones are being developed that won't have this issue as that oils are going away for finishes so quickly.
Painting trim brown to match wood trim? Sofia26 Painting 2 12-10-2012 11:23 PM
painting lead trim? gt1935 Painting 3 11-12-2010 10:55 AM
painting trim and base boards fabian Painting 19 10-10-2010 02:48 AM
Advice needed for Exterior Trim painting fordman289 Painting 2 07-16-2009 02:10 PM
painting walls w/oak trim THEBIGPUNN Painting 3 04-25-2006 03:28 PM
