Old 04-07-2009, 10:26 PM   #1
Anyone PAINTED wood trim?
I have wood baseboards that were stained brown.
My wife wants white trim, or to restain the faded brown trim.
Can I do either? I've been told that it is a total headache to paint the brown trim (trim plus doors,etc) white...and that you can't restain the old stained wood.
Any help?
hellothere123 is offline   Reply With Quote
Old 04-08-2009, 06:39 AM   #2
Remodeling Contractor
Re-staining would require completely sanding the trim down to raw wood, since the stain needs to penetrate into the wood and the top coats and sealer will prevent this. Also you will need to remove the trim to do this work. Poly shades can be used to cover the trim and get a similar finish but toned as your wife wants. But this is a tough to make this stuff look good. Painting over it is not hard. Use a primer first, then paint with two coats.
Old 04-08-2009, 01:03 PM   #3
Well, trim takes longer to paint than walls, but it is not a horrible task either.
SirWired
sirwired is offline   Reply With Quote
Old 04-08-2009, 05:58 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
If it hasn't been poly'd, you can re-stain the same or darker color
If it's been poly'd, you can use polystains or a gel stain (again, the same or darker)
Regardless, if you want to paint it's a coat of oil/alkyd primer and two coats paint or preferably enamel, water-based or oil/alkyd
If you have stain (w/ or w/o poly), and want it lighter, it's a full strip, and most likely more efficient to remove to re-trim, and go from there
So, depending on what you have and what you want, it could be slightly more labor intensive to re-paint
Also, depending on what you have and what you want, it may be your best alternative
slickshift is offline   Reply With Quote
Old 04-08-2009, 09:36 PM   #5
thankyou for your information
its much appreciated!
Old 04-08-2009, 10:11 PM   #6
The techniques have been hit on on. Search for posts on painting trim. You just can't roll it on like a wall. Take your time.Make 2 thin coats. Use oil based if you for a better finish.
beerdog is offline   Reply With Quote
Old 04-09-2009, 08:16 AM   #7
wood trim can be painted ahead of time and then touched up once it is installed, or it can be painted in place, as with existing trim. When you apply two coats of semigloss or gloss paint to your trim, as is often the case, ensure a good bond by sanding lightly between coats and cleaning the dust it with a cloth.
Dana
Dana11 is offline   Reply With Quote
Old 04-09-2009, 07:19 PM   #8
slickshift's Avatar
Your welcome
...anytime
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Tile with a wood trim? trick29392 Flooring 3 06-26-2008 08:19 AM
