Anyone Ever Painted This Type Of Stucco Before? - Painting - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 02:39 AM   #1
Anyone ever painted this type of stucco before?
Need some tips or advice I am repainting a 1960's bungalow but have never painted over this type of stucco, It has white crushed rocks on it and when i glide my hand over it the rocks very easily fall off, if painted i would think the rocks would fall off and reveal the old color, what would be the best method to get this stucco painted properly?
the stucco looks exactly like this but without the broken crushed glass.
very similar home i am trying to paint
TrevorPhilips is offline   Reply With Quote
The Following User Says Thank You to TrevorPhilips For This Useful Post:
billyboys (10-21-2013)
Old 10-04-2013, 12:30 PM   #2
kwikfishron's Avatar
Rewards Points: 998
I'd spray it with a coat (or 2) of peel stop primer. But I'm no painter...
kwikfishron is online now   Reply With Quote
Old 10-04-2013, 06:47 PM   #3
Rewards Points: 6,034
Have never seen stucco like that. Don't think peel stop will work but I can't think of anything better at the moment.
Old 10-04-2013, 07:28 PM   #4
Rewards Points: 998
I've seen it quite a few times in CA and HI. I think PS would be the ticket if you get enough of it on there. It maybe one case of the more primer the better.
The Following User Says Thank You to kwikfishron For This Useful Post:
ToolSeeker (10-05-2013)
Old 10-05-2013, 03:20 AM   #5
Thank's for the reply guys after some research the peel stop primer might be a good way to go but the weather is getting cooler so ill be waiting until summer, What ill try is brush off all the loose rocks then spray 2 - 3 coats of peel stop primer and see how the results are but for now ill wait for other people to chime in see if there are any other methods, Ill keep you guys posted
stucco over stucco sockit Drywall & Plaster 0 02-28-2013 09:19 PM
vinyl siding on stucco on cedar siding Christopher22 Remodeling 0 04-04-2012 02:47 PM
New stucco over old painted stucco exterior Sandstone Remodeling 1 03-31-2011 04:26 PM
stucco over painted stucco problem albert Painting 0 04-03-2010 04:45 AM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 12:22 PM
