Any Way To Turn Satin To Flat? - Painting - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 10:37 AM   #1
Been at it for 45 years
This Old Spouse's Avatar
Rewards Points: 79
Any way to turn satin to flat?
I picked up a couple gallons of mis-mixed paint at the hardware store for pennies. Only problem is that it's satin instead of the flat that I want. Is there anything I can add that will take away any shine?
This Old Spouse is offline   Reply With Quote
Old 04-01-2011, 11:00 AM   #2
Coatings Nerd
Flat paint...and alot of it
If you like the color, you could use it as a first coat then second coat with the same color in Flat.
www.northcromwellpaint.com
Benjamin Moore, Sikkens, TWP, PPG, Airless sales and service
NCpaint1 is offline   Reply With Quote
Old 04-01-2011, 09:42 PM   #3
ltd
Rewards Points: 536
hey just use it take advantage of the deal you got . i would say 75/percent of the walls i roll are satin , its ok
ltd is offline   Reply With Quote
Cannot match sheen on flat paint? infiniti23 Painting 4 12-10-2010 04:35 PM
Need to gain height at right-angle turn (go from 8" drop to 4" drop from 90* and T) aviator79 Plumbing 8 11-06-2010 11:42 AM
Best way to replace/insulate a flat tar-gravel roof Hexar Roofing/Siding 19 10-08-2010 12:17 AM
Flat or Satin? Gary Sutherland Painting 7 09-27-2010 10:29 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
