Any Problems Caused When Painting Wall Studs - Painting - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 09:29 PM   #1
Any problems caused when painting wall studs
I have a number of wood studs exposed in an indoor playhouse I built. I wanted to paint the studs - partly for cosmetics, partly to discourage termites.
I know it is unusual to paint studs, but any concerns I should be aware of long term problems the paint will cause? I'm thinking moisture problems since the wood can't "breathe", but not sure.
sxn77 is offline   Reply With Quote
Old 01-28-2013, 09:52 PM   #2
Rewards Points: 13,450
Unless it's just for looks studs that are inside a building do not need to be painted. Moistures not going to effect them.
It will have 0 effect on termites.
What was important is to build it up off the ground enough so you do not get splash back on the siding when it rains.
Any 2X pressure treated lumber is not direct ground contact rated. Needs to something like 4 X 4, 4 X 6, or 6 X 6 to be direct ground contact rated.
Walkout Basement Wall Problems in NH Sereguial Building & Construction 4 04-18-2011 10:53 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Finding wall studs jmfma General DIY Discussions 8 01-03-2010 05:06 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
