Old 01-06-2013, 01:44 PM   #1
Another Question!!
I try to read all the posts concerning trim and cabinet painting, so I'm just asking for some clarification on this process.
My paint is Muralo WB Satin, over Insul-X Stix primer. Application method is HVLP.
I'm very happy with the look and the sheen. However, I'm wondering if the black marks when something rubs against it are normal. Also, how do I remove the marks? I use a "magic pad" for lots of things, but I don't want to use it on painted surfaces at all.
I've found some internet sites that recommend the following, but I've also seen others say it's not the way to go. Why or why not?
"Mixing waterbourne paint and a "pre-cat" waterboure clear finish" and applying it with an HVLP for a "harder" finish.
I've got lots of trim work and cabinets left to do, so if I can get a "better" finish than the paint alone, I don't mind an additional step or two.
JamesRW is offline   Reply With Quote
Old 01-06-2013, 01:59 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Another Question!!
What is causing the marks?
How long has the paint cured?
Muralo satin (or semi) is great stuff- you have a good program going.
I have been able to clean marks off of it with nothing more than a wet rag.
But make sure it has cured before getting to physical with it- 3-4 weeks.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-06-2013, 02:46 PM   #3
Another Question!!
Paint cured about 10 days before the carpet was laid. Installers did a good job and were careful - especially around the base. A few touch ups needed, but not too bad. A few marks could have come from moving furniture, but I'm thinking most were from people's suitcases and children's toys over Christmas, so that was at least 6 wks cure time for the paint.
If the wet rag alone doesn't remove the mark, what's the next best thing to try (that won't damage the sheen)?
Old 01-06-2013, 03:00 PM   #4
Another Question!!
Just try to be logical- a little all purpose cleaner on the rag.. then move up the scale.
Are you talking about wall paint or trim? You said cabs, but that shouldn't be in the line of fire for baggage..
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (01-07-2013)
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
