Another Q Re: Oil Or Latex, Etc.. - Painting - DIY Chatroom Home Improvement Forum
Old 04-10-2008, 05:19 PM   #1
Another Q re: oil or latex, etc..
I never knew how complicated painting (or rather preparing to paint) would be!
So after being told by a painter that my walls were probably oil based paint, I did the test with alcohol and found that some of it is actually not oil based. Now in the bedroom, the walls, ceiling and door frames are the same color. When I do the test on the wall/ceiling, the color comes off, but on the wood door frame, it does not. So do you think they used oil based on the doors? Do I then have to prime it with an oil based primer first? Or could there be some other reason that it doesn't come off from the wood?
Corcoran1 is offline   Reply With Quote
Old 04-10-2008, 08:38 PM   #2
A lot of painters like to use oil on trim work or doors because it will flow out better so it's very possible. As long as everything is in good shape on the walls you really won't need to prime. As for the door, your call. If its got a sheen, you may want to prime it first just to ensure that the paint sticks.
Also, as many people on here would, I would recommend going to a paint store to get your paint as you are likely to have adhesion problems with the quality paints they sell than if you go with one of the big box stores.
DIYHelper is offline   Reply With Quote
Old 04-10-2008, 10:46 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Did you do the test with alcohol or with denatured alcohol?
There's a huge difference
slickshift is offline   Reply With Quote
Old 04-11-2008, 10:45 AM   #4
Should it have been denatured alcohol?
abelsu is offline   Reply With Quote
Old 04-11-2008, 07:37 PM   #5
slickshift's Avatar
Yes
Denatured
Isopropyl/rubbing, ethanol/booze......those won't do it
Oops! or Goof Off! will work for the test though,if you have either on hand
Old 04-11-2008, 08:08 PM   #6
Rewards Points: 506
Actually, denatured alcohol is simply grain alcohol that has been modified to make it undrinkable. That said, denatured alcohol is much cheaper than pure grain from the liquor store, since it is not taxed like booze.
SirWired
sirwired is offline   Reply With Quote
Old 04-11-2008, 10:11 PM   #7
slickshift's Avatar
Ha ha ha ha....
I did not know that...lol...
I was just trying to say that old Christmas present of a bottle of undrinkabley bad scotch from Uncle Harry isn't going to work as a paint tester either...lol
Thanks for the clarification!
Already painted latex over high gloss, looks terrible, help! AbbyTeters Painting 9 10-25-2007 09:38 AM
polyurithane over latex paint spharris Painting 3 08-27-2007 12:01 PM
oil to latex error my5cats Painting 3 02-10-2007 09:25 AM
Do latex and water mix? eric s Painting 2 11-28-2006 04:25 AM
Latex over Gloss 'Andyman Painting 4 10-02-2005 09:49 AM
