Another Primer Question - Painting - DIY Chatroom Home Improvement Forum
Old 08-02-2013, 09:28 PM   #1
Rewards Points: 105
Another primer question
Hello-
I need recommendations for the best wood primer. I have cracking latex pain on my fascia boards and some rust stains. Also, is there a good SW product that skips the priming? Thanks.
r1racer is offline   Reply With Quote
Old 08-03-2013, 02:06 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
Originally Posted by r1racer View Post
Hello-
for the primer, maybe this
Old 08-03-2013, 06:55 AM   #3
Too Short? Cut it Again!
If you need a primer, and you do, with a stain blocker!
The there is no way or reason to skip it. Especially in your situation there is no primer and paint product in one.
I am guessing these are steel nails that are rusting? You might want to pick up a rattle can of something like Rustoleum's rust converter and spot prime the bleeding nail holes with it.
Then something like Chris mentions from SW will work fine. Ben Moore's Fresh Start will work too. The solvent based alkyd stuff is pretty amazing.
Once you neutralize the nails bleeding, Zinsser 123 Plus with a stain blocker might be a decent waterbased alternative.
Old 08-03-2013, 07:25 AM   #4
Rewards Points: 105
Ah well...was hoping I didn't have to do a two stepper. Thanks.
Old 08-03-2013, 07:31 AM   #5
Rewards Points: 105
One more question, which is better, the Zinsser or the oil based primer?
Old 08-03-2013, 07:35 AM   #6
Rewards Points: 14,026
90% of a proper paint or stain job is in the prep. Skip a step and you'll just be back doing it again sooner.
So what's rusting? The nails from lack of mantaince, or someone used galvanized drip cap?
If it's the drip edge, it can be replaced with aluminum or cleaned up and repainted to get some more life out of it.
That fascia can also be wrapped with aluminum coil stock so it would never need to be painted again.
Old 08-03-2013, 07:43 AM   #7
Rewards Points: 105
Drip cap has pealing paint that is causing the rust in small areas and the roof is causing black stains on the fascia. My gutters are hidden as a part of the roof so when it rains hard it simply pours over the fascia. Whoever put the roof on did a poor job laying down the shingles (rolled roof).
Old 08-03-2013, 09:09 AM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
I have seen those. When the gutters wear out, and they will, you will have a mess on your hands.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 08-03-2013, 09:17 AM   #9
I think you mean some sort of Gutter Helmet product, perhaps its dirt cheap vinyl cousin?
Take them off. Pay to have your gutters cleaned a couple times a year. You will be much happier.
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 08:00 AM
Masonite repair primer and paint wdpcpa Painting 7 11-15-2012 04:56 PM
TO PRIME OR NOT TO PRIME that is the question ToolSeeker Painting 7 09-29-2012 07:57 AM
Primer question mikethefinfan Painting 2 08-15-2012 07:19 AM
Please help! I'm repainting bedroom furniture and primer is "gunking"! Fun2Learn Painting 12 02-13-2012 06:54 AM
