Old 11-27-2009, 03:41 PM   #1
Amount of coats of primer and paint
im painting my closet hangers, the framing and the hanging pole is wood, so i want to know how many coats of paint and primer do i have to do to do a good job?
humberguy is offline   Reply With Quote
Old 11-28-2009, 08:45 AM   #2
ccarlisle's Avatar
How long is a piece of string? No one answer to that either...The answer isn't out of a trade manual but will depend on your local parameters.
ccarlisle is online now   Reply With Quote
Old 11-28-2009, 09:38 AM   #3
About 400 sq. ft / gallon; primer likely less. Cans have approximate coverage on them. Measure your walls, add up the sq. ft and then do the division.
bob22 is offline   Reply With Quote
Old 11-28-2009, 11:20 AM   #4
sdsester's Avatar
I would ordinarily suggest a coat of primer and two coats of paint for anything but if these are just regular closets and you are doing them in white? I would just prime the raw wood and new drywall (if that is your situation), can spray paint the hardware, and put a good contractor grade paint over everything. Nobody is going to see it much and you will ding up the closet pole with hangers and so forth no matter what you paint it with. If they are designer walk in closets then I would treat them like any other painted room.
sdsester is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
