Old 08-18-2011, 02:01 AM   #1
Aluminum Fenceposts - How to Strip/Repaint?
In our yard, we have a "glass wall system" that is peeling horribly. See http://www.pixgroup.com/fence/fence_hill.jpg
I'm not sure the history (since we bought the home used), but it appears what we we have is…
- Aluminum fenceposts
- Original surface was white powder coating.
- Someone attempted to paint over the white coating with black paint
- Black paint is peeling off
You can see all the layers in http://www.pixgroup.com/fence/fence_closeup.jpg
This was obviously a very poor job, and I'm not sure how to fix it.
MY QUESTIONS:
1) Is there a chemical (or process) that can strip both the paint and powder coating off?
2) After stripping, what sort of paint should I use on the aluminum posts (so the paint won't strip again)?
3) Any other advice for us?
Thank you so much for your help!
idesign123 is offline   Reply With Quote
Old 08-18-2011, 05:42 AM   #2
NACE Coating Inspector
mustangmike3789's Avatar
remove any loose paint down to bare metal. sand/scuff all surfaces and feather rough edges of chipped off paint. power wash to remove dust and loose oxidation from the aluminum. just before applying any paint to aluminum, you should solvent clean with lacquer thinner to remove the layer of aluminum oxide that will form as fast as you remove it. apply one thin coat of sherwin williams wash primer http://apscontractors.homestead.com/...ash_Primer.pdf . followed by two coats of SW dtm acrylic finish coat. http://www.archcommercialpainting.co...c%20Finish.pdf .
mustangmike3789 is offline   Reply With Quote
The Following 3 Users Say Thank You to mustangmike3789 For This Useful Post:
Blondesense (12-11-2011), Gymschu (08-18-2011), idesign123 (08-18-2011)
Old 08-18-2011, 10:00 PM   #3
:: GASP ::
That is EXACTLY the info we needed! Thank you so much for taking time to share your knowledge with us. You've saved us many hours of research (and possibly costly mistakes).
We are very very grateful!
Connecting 4 aluminum wires in a junction box krick Electrical 3 07-21-2012 03:06 PM
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 12:19 PM
Shredding Aluminum Cans bobo General Discussion 36 11-10-2009 03:32 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
