#1 |
Airless paint sprayer or compressed air spray paint gun
I am looking to start painting bikes or other metal things so my question is which method will turn out with a better result a airless paint sprayer or an air compressor with a spray paint gun attached
#2 |
Super Moderator
For fine painting you want an HVLP gun(high volume low pressure) with a turbine or a compressor.
An old fashioned compressor driven gun will also work,but wastes a lot of paint and requires a big compressor. I've got two turbines and they are very quiet and don't take a lot of space.--Mike---
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
Rubbin walls since'79
I agree- but it also depends on what kind of paint you want to spray.
For a real fine solvent base a conventional might be better. And you can get a gun that can dial down the amounts to almost pinstriping. For waterborne ( and also some solvents) HVLP does wonders. I would check with other bike dealers and see what they use- pretty specialty. Most of us here work on a little bigger scale.. Let me correct this after rereading your post. I think airless is out of the question. The decision is between conventional ( uses a compressor- not airless) and HVLP. Google is your friend if you want to know the setups. Last edited by Brushjockey; 07-04-2011 at 08:33 PM. |
#4 |
Thank you all for your help
#5 |
handpaintedbysteve.com
Hey bikerway,
If you were painting ten bike frames all the same color, an airless unit with a fine finish tip would be worth the effort, but if all that you’re painting is one frame then I would go with the conventional set up or the HVLP. Clean up time using an airless on one frame couldn’t be justified, and to do it right you would need a respectable airless unit for at least $700+.
Best of Luck Steve To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to spraygunn For This Useful Post: | Tom Struble (07-04-2011) |
| Display Modes | |
| Milwaukee Airless/ Fine Finish Paint Sprayer (good or bad?) | ehoez | Painting | 3 | 10-09-2010 02:56 AM |
| Paint for HVLP sprayer | Mike in Arkansas | Painting | 6 | 01-24-2010 05:44 PM |
| New Construction: Airless Paint Sprayer questions | Karde | Painting | 10 | 01-15-2009 05:55 PM |
| unsticking an airless paint sprayer | chrisusvi | Painting | 7 | 02-25-2008 10:34 AM |
| I need a few tip's for airless paint sprayer | Doug Crf | Painting | 1 | 04-06-2006 08:55 PM |
