-   -   Airless paint sprayer or compressed air spray paint gun (http://www.diychatroom.com/f4/airless-paint-sprayer-compressed-air-spray-paint-gun-109678/)
bikerway 07-04-2011 06:29 PM
I am looking to start painting bikes or other metal things so my question is which method will turn out with a better result a airless paint sprayer or an air compressor with a spray paint gun attached
oh'mike 07-04-2011 06:42 PM
For fine painting you want an HVLP gun(high volume low pressure) with a turbine or a compressor.
An old fashioned compressor driven gun will also work,but wastes a lot of paint and requires a big compressor.
I've got two turbines and they are very quiet and don't take a lot of space.--Mike---
Brushjockey 07-04-2011 07:30 PM
I agree- but it also depends on what kind of paint you want to spray.
For a real fine solvent base a conventional might be better. And you can get a gun that can dial down the amounts to almost pinstriping.
For waterborne ( and also some solvents) HVLP does wonders.
I would check with other bike dealers and see what they use- pretty specialty. Most of us here work on a little bigger scale..
Let me correct this after rereading your post. I think airless is out of the question. The decision is between conventional ( uses a compressor- not airless) and HVLP. Google is your friend if you want to know the setups.
bikerway 07-04-2011 08:11 PM
Thank you all for your help
spraygunn 07-04-2011 08:20 PM
Hey bikerway,
If you were painting ten bike frames all the same color, an airless unit with a fine finish tip would be worth the effort, but if all that you’re painting is one frame then I would go with the conventional set up or the HVLP. Clean up time using an airless on one frame couldn’t be justified, and to do it right you would need a respectable airless unit for at least $700+.
