Airless Paint Sprayer - Painting - DIY Chatroom Home Improvement Forum
Old 11-23-2012, 09:33 PM   #1
airless paint sprayer
If I'm painting a room ceiling white and walls another color, what is the sequence in airless paint spraying? Walls first then ceiling or ceiling first then walls? Wall paint is eggshell finish. House is empty, no finished floors, no trim yet, new sheetrock already primed.
stevo37k566 is offline   Reply With Quote
Old 11-23-2012, 09:39 PM   #2
Rewards Points: 14,014
I would very strongly suggest you just use a roller and a brush.
By the time you taped, masked, protected the floor, plus all the added clean up you could have painted the room and had no over spray.
Old 11-23-2012, 09:46 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
First- do you know how to set up to spray? have you it before?
Lots of masking.
if you know how to cut and roll, I'd say drop poly from the ceiling line and do ceiling, cut and roll walls.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-24-2012, 07:59 AM   #4
Rewards Points: 5,988
Since the house is empty. I would use hand masker (whice cuts masking by more than half) with a roll of 9' plastic, mask the walls, spray, then using a paint shield and a pretty small tip for better control spray the walls.
Old 11-25-2012, 12:07 AM   #5
Paint Pro
spray walls, then mask off walls with a hand masker making clean tape lines. drape the plastiic on the walls and then spray the ceiling. spraying into properly taped masking film leaves perfectly clean lines with no bleed. dont even need to caulk the tape.
Expert Paint is offline   Reply With Quote
The Following 2 Users Say Thank You to Expert Paint For This Useful Post:
stevo37k566 (11-25-2012), ToolSeeker (11-25-2012)
Old 11-25-2012, 12:26 AM   #6
Painting the walls, masking them and painting the ceiling works for me. Thanks
Old 11-25-2012, 01:28 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Good comments here.
I have an airless....and based on my experience.....you have to pick and choose the projects that you want to use it on.
As noted above....it's a good 10-15 min of work to just clean the airless sprayer after using it...so I only use mine when I have a lot of stuff to cover.....or, it has a lot of 'detail' that a bruch or roller will not cover very well.
And just so it's clear...just because it's an airless, it does not mean you get a lot of overspray....because you WILL get a lot of overspray.
ddawg16 is online now   Reply With Quote
Old 11-25-2012, 07:01 AM   #8
Has anyone used the power roller with their airless rig. The promotion with my Graco sprayer the power roller came with it. It sat in my garage the past few years because I didn't think much of it I guess. Used it a short while ago on an exterior stucco job where we could't spray 1 area. It was a heavy stucco so to just roll it was taking a long time, hooked up the power roller to try it and it was fantastic. And you can buy different nap roller covers. Just wondered if anyone else has tried it.
Old 11-25-2012, 08:11 AM   #9
Too Short? Cut it Again!
Don't forget to back roll the spray work!
As for the power roller question. The internal feed covers are expensive and tend to be messy, from my experience. But I was cleaning up after somebody who used one of the Wagner toys. Hardly worth it for a single room. Maybe worth thinking about for a whole house.
The Following User Says Thank You to user1007 For This Useful Post:
ToolSeeker (11-26-2012)
Old 11-25-2012, 08:37 AM   #10
A long time ago I used a power roller and found that it would be OK for rolling something that didn't need a fine finish, but was very tricky to lay off on something like interior walls with an eggshell or something like that.
The Following User Says Thank You to Brushjockey For This Useful Post:
509 Wagner Professional Airless paint sprayer davvid20120 Painting 1 04-02-2012 09:12 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Airless paint sprayer or compressed air spray paint gun bikerway Painting 4 07-04-2011 08:20 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
Paint Sprayer Recommendation jpb Painting 2 02-24-2008 01:45 PM
