airless finish window trim
It will be a lot quicker and easier in your situation to brush the trim. If you use an airless to spray the trim in a furnished home that the ceiling and walls are already painted in you will have paint from the airless all over. An airless puts paint out very high pressure dispersing a lot at one time causing a lot of fine particles of paint in the air, then the particles drift. Even with a fine finish tip you are only making the fan smaller, but you'll still have high output of paint. You would have to remove everything from the room, cover the floor with paper and tape, tape and paper any fixtures. Mask off the ceiling, mask off the walls, and doorways to other rooms. By the time you do your prep work, set up the sprayer, and clean up you could have painted the trim by hand with no worries of over spray. If you want to spray trim in your situation you need a HVLP sprayer that puts the paint out at very low pressure with a lot less particles in the air, then there would be very minimal masking or you could use a air assisted sprayer.
