Old 02-19-2013, 12:43 PM   #1
Question
Air Stream L210vkw/L215vkw Air Compressor blowing oil
Hi guy's I have oil blowing out of the dip stick of my air compressor. I noticed the dip stick blown out. I checked the oil, added oil, put the dip stick back in, and when I plugged it in and turned it on it was blowing oil out of a small vent hole in the dip stick cap. Can you guy's please help?
JD King is offline   Reply With Quote
Old 02-20-2013, 08:19 AM   #2
cdaniels's Avatar
This is the painting help part of the site.Your question would be better answered in another part of the forum.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
JD King (02-22-2013)
Old 02-20-2013, 08:47 AM   #3
That number did not come up on there web site so I could see what type it is.
http://www.airstreamcompressors.co.za/piston.asp
I'd be checking the check valve first. If it's leaking back it will leak past the rings and pressureize the crank case.
Next would be the reed valves in the top of the head to see if there broken or dirty.
Shower goes from normal to thin stream of boiling water in 3 mins Michele8 Plumbing 1 08-22-2012 06:06 AM
live charge in water stream? sparky89 Electrical 2 04-21-2012 12:22 AM
Outdoor Sump Pit LMcKee Landscaping & Lawn Care 15 06-10-2010 08:50 PM
Weak stream of water from shower head. SuperAkuma Plumbing 3 08-01-2008 06:49 PM
Stream Radiator - Pipes and Radiators are making noises gforce HVAC 6 01-02-2008 10:58 AM
