Air Sprayer Does Not Work - Painting - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 06:08 PM   #1
air sprayer does not work
Hey guys and gals, I just found this forum. I have a craftsman air sprayer that does not work, not sure of the model. It will spray air but will not spray paint. For some reason it is not building up pressure. It used to me grandpa's sprayer and he said it has never been used, which it has because I took it apart trying to figure it out and it was covered in paint. I am sure it has set awhile but don't know how long. Thanks for any help in advance.
I have another sprayer that I have been using and to me it seems that it does put out that much paint. I have to go real slow and get real close for it to cover good. Can this be fixed by using a different tip? Where would you buy different tips at? The paint I am using recommends a 0.13 or a 0.15 tip but I have no clue what kind of tip I am using.
memory is offline   Reply With Quote
Old 08-18-2009, 06:14 PM   #2
Workaholic's Avatar
Rewards Points: 268
Glad to see you made it here memory! I guess the link worked out for you.
Have you taken the needle assembly apart and cleaned with some lacquer thinner? Does it have a little hose that goes from the cup to the gun that needs cleaned?
Sean
Workaholic is offline   Reply With Quote
Old 08-18-2009, 08:49 PM   #3
Hi, yes the link you provided worked and thanks. It seems that I have got it working. All I did was take apart the pieces that attaches to the cup and put it back to together and now it sprays fine. Sorry for wasting your time on that.
What about different tips? Where can you buy them at?
Old 08-19-2009, 08:33 AM   #4
Coatings Nerd
Check on the brand of sprayer, some you can replace tips, others have an adjustable tip, depends on the brand. Or maybe a pic of the gun if you dont know what brand.
I sell, rent, and repair most airless sprayers so I should be able to answer if I have a bit more info.
NCpaint1 is offline   Reply With Quote
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
Does your job require a permit? housedocs General DIY Discussions 203 12-01-2010 07:28 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
Trying to get swith to work... mntentman Electrical 4 09-19-2008 08:54 PM
DIYers and Professionals Can Work Together. WilbUild Building & Construction 5 04-08-2007 01:43 PM
