After Top Coat, Isolated Flaws... Quick Fix?? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 04:16 PM   #16
Use BM Muresco, Ultra Flat Ceiling finish, or at least Super Spec. Merry Christmas all!
PS
and if that offends you, get over it.
Old 12-27-2012, 06:38 PM   #17
cdaniels's Avatar
Originally Posted by Adrenalinejunky View Post
I think Im leaning toward not liking SW HP ceiling paint as well. After improving some drywall flaws and covering the stain, I applied a second coat. 1/2 of the ceiling came out acceptable but the other half shows roller marks. I attempted a third coat over the half that looked bad, it improved it but it still looks bad IMO.
SW rep said it couldve been a bad batch so I tried a new batch with the third coat. They also mentioned using their Cashimere or all in one paint. I think Im going to switch to a different paint for the ceiling, any opinions for SW paint?
Pro Mar 200 in flat
cdaniels is offline   Reply With Quote
Old 12-28-2012, 11:36 PM   #18
PS
Originally Posted by cdaniels View Post
Pro Mar 200 in flat
Im guessing these are not Sherwin Williams paints? I wanted to stick with the Sw lineup, considering their cashmiere or paint primer in one for the ceilings.
Adrenalinejunky is offline   Reply With Quote
Old 12-28-2012, 11:41 PM   #19
cdaniels's Avatar
Yes the Pro-Mar is a SW paint
Does not have to be a "ceiling paint" any flat paint will do the job.
Charlie Daniels painting and repair
The Following User Says Thank You to cdaniels For This Useful Post:
Adrenalinejunky (12-29-2012)
Old 12-29-2012, 02:56 AM   #20
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
As c daniels said, promar 200 is SW and cashmiere would be over kill for a ceiling
The Following User Says Thank You to chrisn For This Useful Post:
Old 01-03-2013, 08:58 PM   #21
I tried the Pro Mar 200 flat. It applied nicely, but as it began to dry it looked worse than before. Thankfully after it fully cured it smoothed out and was an improvement! Is it perfect, no but I think I can live with it. Maybe the other rooms will come out better.
The other ceilings have drywall repairs and will first be spot primmed. How many coats of the top paint are normal?
Old 01-03-2013, 11:31 PM   #22
cdaniels's Avatar
I would go ahead and put on two coats.
Adrenalinejunky (01-09-2013)
Old 01-04-2013, 05:02 AM   #23
chrisn's Avatar
Rewards Points: 228
2 ,TWO, always
no matter what you read about one coat coverage
it does not, never has and most likely never will
even with good eyes
Old 01-04-2013, 07:38 AM   #24
Agree with cdaniels and chrisn, always two coats. One coat, even white over white on a ceiling, will not give the depth and uniformity of two. One will give a shadowy, uneven look.
The Following User Says Thank You to jsheridan For This Useful Post:
Old 01-04-2013, 07:47 AM   #25
Rewards Points: 5,974
On ceilings I always put the first coat i direction 2nd coat opposite direction. Ceilings can be difficult to get even cover this seems to help.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 01-09-2013, 08:51 AM   #26
SW Rep pointed me to tinting the pro mar to bright white... What color white do you guys like?
Old 01-09-2013, 12:23 PM   #27
cdaniels's Avatar
Of course that is personal preference but I like my ceilings as white as I can get 'em.
Old 01-10-2013, 08:19 AM   #28
Me too but I have found when a lot of them dry they have a grey cast to them
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 01:53 AM
Sherwin Williams question... 1 coat or 2? MatP Painting 4 06-09-2012 09:52 AM
skim coat over skim coat? drke Drywall & Plaster 0 11-28-2010 10:07 AM
Level 5 Smooth Wall + Priming fred s Drywall & Plaster 10 11-10-2010 05:54 PM
Quick, dirty way to fix this? pro_DIYer Painting 8 05-15-2008 08:47 AM
