After Staining Wood - Painting - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 01:37 PM   #1
sweaty
Rewards Points: 276
After Staining Wood
I just stained my stair railings. They are drying outside.
Dust particles have lodged onto it. What is the best way to clean it without scratching the railing?
sweaty is offline   Reply With Quote
Old 08-09-2012, 03:28 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 816
00 (super fine) steel wool
Old 08-09-2012, 03:33 PM   #3
Rewards Points: 12,818
If it was stain right there should be so little stian on the surface there's nothing for the dust to stick to and could just be wiped off with a dry lint free cloth.
Old 09-01-2012, 05:48 PM   #4
Bombastic Idiot
notmrjohn's Avatar
Could be the dreaded "Finish and stain in one can." I've had dust stick to stain, sands right off with real fine emory cloth or steel wool.
sweaty, when you apply your finish do it indoors and let it dry away from moving air. Outdoors is too dusty and breezy.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-01-2012, 11:03 PM   #5
Too Short? Cut it Again!
Yup! Follow with a soft cloth.
Old 09-01-2012, 11:09 PM   #6
Rubbin walls since'79
Brushjockey's Avatar
I think I have used steel wool once in my career. Found out little bits get into stuff. And rust if using any waterborne.
Just use the right grit sanding sponge or hand piece for sanding.
As far as dust in the stain- NMJ has it I think. Stain itself should not get stuff in it that cant be wiped off with your hand, unless you're doing it wrong.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-02-2012, 04:04 PM   #7
Bombastic Idiot
notmrjohn's Avatar
Originally Posted by Brushjockey View Post
,,, little bits get into stuff. And rust....
Electro-magnetic dusting cloth
But yeah, you're right. I do use it on metal stuff some times, but mostly emory cloth, especially incredibly fine wet on a hard final finish like the body shop boys do. (ever made dark antique oak stain from vinegar and steel wool? Rub vinegar into oak with wool, real deep rich color, can go all way to black using more vingar, and really deep penetration too, still some bits but don't worry about rust. Learned the recipe from my aunty, you may know her, she has shoppes all over, Anti Que?
" NMJ... wrong. " So many times we've those two in the same sentence. Sigh.
Question About Staining a Wood Deck LittleBonnie Painting 0 05-12-2011 11:52 AM
using soft wood sealer prior to staining minchu Painting 0 06-21-2010 12:16 PM
staining raw weathered wood pleasehelpme Painting 2 06-17-2009 06:55 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? proofer Painting 2 04-05-2008 08:47 PM
