After Applying Wood Filler, How Long Can I Wait To Sand? - Painting - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 02:11 PM   #1
Rav
Rewards Points: 564
Question
After applying wood filler, how long can I wait to sand?
I'm in the process of refinishing (re-painting) a wood door. I've cleaned the door with Dirtex and am about to fill small cracks and holes with Minwax stainable wood filler. (I will ultimately fine sand the entire door to rough it up and prime with X-I-M UMA, but that's another day.) I know that the repairs can be sanded once they dry, between 2 hours (shallow areas) to 6 hours (deeper areas). The question is, do I HAVE to sand them AS SOON as they are dry? Stated another way, if I apply the filler today but then wait a day or two to spot sand the repairs, is that OK, or will they be "too dry" or something? Thanks.
Rav is offline   Reply With Quote
Old 07-29-2012, 02:14 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
No problem to wait.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (07-29-2012)
Old 07-29-2012, 02:46 PM   #3
Too Short? Cut it Again!
Best to wait and let it cure completely.
The Following User Says Thank You to user1007 For This Useful Post:
Old 07-29-2012, 08:36 PM   #4
Paint Pro
can never wait too long
Expert Paint is offline   Reply With Quote
Old 07-30-2012, 09:35 AM   #5
Rewards Points: 14,020
I need to clean my glasses.
Old 07-30-2012, 09:45 AM   #6
Rav
Rewards Points: 564
Originally Posted by joecaption View Post
Wood filler used on a hardwood floor
Even "stainable" wood filler will stick out like a sore thumb when finished.
What happens to the wood when the wood expands and contracts with the changing humity levels if the gaps or cracks have been filled?
Hi, Joe. Not sure why you said "floor;" I'm doing a door. At any rate, what would you suggest I use instead to fill small cracks in the door? Afterwards I'll be spot sanding the repairs, light fine sanding the entire door, spot priming with X-I-M UMA, then priming the entire door with same, then one and perhaps two coats of Duron Signature Select interior acrylic semi-gloss. Are you saying even with all that the filled areas will eventually stick out? Thanks for your input.
Tags
filler , sand , wood
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Stripping Moulding; is this wood filler or primer? MEE123 Painting 19 08-09-2012 03:31 AM
Wood Filler Suggestions for Outdoor Elements-(Waterproof!) HandyDave General DIY Discussions 5 02-28-2010 03:53 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
