Old 03-20-2009, 07:10 PM   #1
diy'er
la15ota's Avatar
advice on stripes on textured walls
Last week we painted the textured walls with a new coat of paint. It turned out even better then expected.
I'd like to paint horizontal stripes on the walls.
I plan on using blue tape to set the boundaries. Are there any suggestions on how to avoid bleeding under the tape?
I've read that I should paint over the edge with the wall color to seal the taped edge and then paint over it with the actual color once its dry.
Any other advice?
la15ota is offline   Reply With Quote
Old 03-21-2009, 12:56 AM   #2
Matthewt1970's Avatar
You are really hard pressed to have paint not go under tape on a smooth wall, much less a textured wall.
Old 03-21-2009, 06:25 PM   #3
Drywall contractor
Don't really see how you could avoid it......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-25-2009, 12:50 PM   #4
diy'er
la15ota's Avatar
I've decided I want to put up stripes...I'm looking for additional help and support. I already know that it will be a difficult task...so please only reply if you've got better suggestions.
Old 03-25-2009, 01:19 PM   #5
Try them by hand. Maybe snap a chalk line or use a laser level, but the tape on a textured wall will not help. Paint will inevitably creep under the tape when stuck to a flat surface so a textured wall with the hills and valleys is sure to have paint creep under it and not give you the straightest lines anyways.
Old 03-29-2009, 09:38 PM   #6
diy'er
la15ota's Avatar
Lots of taping.
Then painted over the seams of the tape with wall color.
Almost finish product, nice sharp edges.
Next weekend I'll fill in the gaps between the orange and green with dark blue...more tape here I come
Old 03-30-2009, 12:08 AM   #7
Those are textured walls? Looks good.
Old 03-30-2009, 11:00 AM   #8
Drywall contractor
Yes it does! Who'd of thunk it??
Old 04-05-2009, 01:00 AM   #9
diy'er
la15ota's Avatar
Well here's the final product.
Just a few minor touch ups with bleeding by the door trim, but overall very satisfied with the end results.
Lessons learned, you need to be a little OCD to do stripes.
Laser levels are awesome. Taking your time and not rushing is very important. Finally stripes can be done on textured walls.
Final Product:
Old 04-05-2009, 02:03 PM   #10
Drywall contractor
VERY nice!
Old 04-05-2009, 04:34 PM   #11
Drywall and Painting Pro
Sir MixAlot's Avatar
Turned out nice! That's how we do it. The old clear caulk trick works aswell.
Checkout some of
Sir MixAlot is offline   Reply With Quote
faux finishes on already textured walls aimless07 Painting 5 11-04-2008 11:05 PM
painting over textured walls letigre Painting 3 07-29-2008 05:12 PM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
Textured walls Dafeesh Painting 5 03-04-2008 10:58 PM
Help with new cracks in textured walls Giants2112 Building & Construction 3 01-25-2008 08:23 PM
