-   -   advice on stripes on textured walls (http://www.diychatroom.com/f4/advice-stripes-textured-walls-40765/)
la15ota 03-20-2009 07:10 PM
Last week we painted the textured walls with a new coat of paint. It turned out even better then expected.
I'd like to paint horizontal stripes on the walls.
I plan on using blue tape to set the boundaries. Are there any suggestions on how to avoid bleeding under the tape?
I've read that I should paint over the edge with the wall color to seal the taped edge and then paint over it with the actual color once its dry.
Any other advice?
Matthewt1970 03-21-2009 12:56 AM
You are really hard pressed to have paint not go under tape on a smooth wall, much less a textured wall.
bjbatlanta 03-21-2009 06:25 PM
Don't really see how you could avoid it......
la15ota 03-25-2009 12:50 PM
Looking for help...
I've decided I want to put up stripes...I'm looking for additional help and support. I already know that it will be a difficult task...so please only reply if you've got better suggestions.
Matthewt1970 03-25-2009 01:19 PM
Try them by hand. Maybe snap a chalk line or use a laser level, but the tape on a textured wall will not help. Paint will inevitably creep under the tape when stuck to a flat surface so a textured wall with the hills and valleys is sure to have paint creep under it and not give you the straightest lines anyways.
la15ota 03-29-2009 09:38 PM
It works
Lots of taping.
http://la15ota.smugmug.com/photos/501488277_fFke5-S.jpg
Then painted over the seams of the tape with wall color.
Almost finish product, nice sharp edges.
http://la15ota.smugmug.com/photos/501491000_549sE-S.jpg
Next weekend I'll fill in the gaps between the orange and green with dark blue...more tape here I come
Matthewt1970 03-30-2009 12:08 AM
Those are textured walls? Looks good.
bjbatlanta 03-30-2009 11:00 AM
Yes it does! Who'd of thunk it??
la15ota 04-05-2009 01:00 AM
Final Product
Well here's the final product.
Just a few minor touch ups with bleeding by the door trim, but overall very satisfied with the end results.
Lessons learned, you need to be a little OCD to do stripes.
Laser levels are awesome. Taking your time and not rushing is very important. Finally stripes can be done on textured walls. :yes:
Final Product:
http://la15ota.smugmug.com/photos/505528438_QwAiJ-S.jpg
http://la15ota.smugmug.com/photos/505528685_mqeZK-S.jpg
bjbatlanta 04-05-2009 02:03 PM
VERY nice!
Sir MixAlot 04-05-2009 04:34 PM
Turned out nice!:thumbsup: That's how we do it. The old clear caulk trick works aswell.:whistling2:
