-   -   Advice on painting edge next to tile (http://www.diychatroom.com/f4/advice-painting-edge-next-tile-166045/)
stuvwxyz99 12-09-2012 03:36 PM
2 Attachment(s)
I'm looking for advice on how to get a good edge between my bathroom tiles and the painted wall. We are going to change the color of the existing wall. This was painted in the summer when we did a bathroom remodel, but we have decided to change the color. The tile is a crackled glaze, and pencil tile was used as an edge. I have attached some photos to show how it currently looks. The glass tiles in the border are 1 inch square, to give you an idea of scale.
As a complete newbie, I'd like to know how to get a nice edge between the painted wall and the pencil tile. As you will see from the pictures, the previous attempt (not by me, btw) was not too good.
Brushjockey 12-09-2012 03:42 PM
This is a tricky spot- because it is not even, an it is rough.
One way is to tape the line, finger and blade tape down hard, then take caulk or a clear primer like Gardz or Peel Bond and seal the edge of the tape. paint and then you might have to carefully score the edge of the tape so it doesn't pull up paint, and remove at a 45% angle.
Sounds harder than it is.
stuvwxyz99 12-09-2012 04:06 PM
Thanks. Can I go over that slowly, just to make sure I completely understand.
So the tape would cover the pencil edge, with the inner edge of the tape along where the existing paint edge is, and then press the tape down hard with a finger, and then with a blade (e.g. a putty knife?)
So a thin strip of caulk or clear primer, so that the edge of the tape is covered by this strip. How wide would the strip be? I'm guessing as thin as possible while still covering both sides of the tape edge? Also, which product would be better, and how is it applied (sorry, I am a real newbie).
How long should i wait before removing the tape? Would the score be very faint, or would it go through the depth of the paint? Should I use a rule to ensure the score is straight?
toastandjam 12-09-2012 04:10 PM
I'd go the old Earl Scheib route. Cover what you don'r want painted with Vaseline and then paint away. Once the painted surface completely dry. Wipe away.
Brushjockey 12-09-2012 04:45 PM
What do you mean by pencil edge? Put the tape where you want your line. On that edge seal it so paint won't creep underneath. Width is not the important part, hitting the edge is. Only one side of tape. where you want your line. Yes putty knife.
Better is what you have. All work.
Scoring should be right on that edge, cutting the paint but not the tape. This is insurance that the paint doesn't peel up on that edge when you pull tape.
I wait until the paint is set- hour or two after painting- then remove.
This gets clearer once you've done it a couple of times.
joecaption 12-09-2012 09:10 PM
Not going to try and fix that messed up plaster looking material first before painting?
Brushjockey 12-09-2012 10:05 PM
Good point. I'd run a putty knife straight down along that edge and clean it up before any of the prior info.
joecaption 12-09-2012 10:10 PM
And prime that area before painting.
Brushjockey 12-09-2012 10:20 PM
And so then how would you prime that and have a clean line, joe?
joecaption 12-09-2012 10:38 PM
How would you and I do it or how would a DIY do it?
I would just use a 2-1/2 sash brush and use a putty kinfe with a rag over over the end of it to wipe any messed up spots.
Using painters tape will also work, just one more step I try to skip.
But I also would have removed that messed up tri that looks like it was split and patched up before doing anything.
stuvwxyz99 12-09-2012 11:51 PM
I got lost in that discussion :-)
Should I get someone in to help with this, or can a DIYer make a decent patch-up?
Edited to add:
Is it just the area in the second pic that has problems? There is just a small area (maybe a linear foot, or less) that looks like that, while most of it looks like the first pic.
joecaption 12-10-2012 12:03 AM
We only have the pictures you posted to go by, but it almost looks like at one time there was a a window there, someone filled it in, added the tile, then made the big mistake of painting the grout.
I'm seeing a patched up piece of trim, and a recess that has no reason for being there. All it's doing is causing mold to grow in the corner.
If it was mine I would rip it all out and do it right.
jsheridan 12-10-2012 05:34 AM
This is starting to sound a bit Keystone Cops.
OP, take a razor knife and run it parallel with the wall. Position some finger between it and the wall for spacing with one hand and use the other hand on the blade, now you have a support and guide to run the blade around the grout/tile edge and clean that line up.
Run a bead of thin caulk in that grout area and wipe it with a wet rag.
Let that dry then paint right up to the tile edge and cover the grout/caulk area. You can prime it prior if you wish but I don't think that's necessary.
To clean the edge up and straighten the line, you can use a wet rag on a putty knife, but I don't think you get quite the control that you would get using a rag over your thumb. With the rag over your thumb, pull the pad of your thumb back and press down on the edge and now between the pad and the nail you have a wiper and a guide in one and it locks in and slides right along creating a perfect line everytime. Your hands and fingers are perfect tools themselves, for more than holding tools.
stuvwxyz99 12-10-2012 08:05 PM
2 Attachment(s)
No windows in this bathroom (it's an apartment building - there is a pretty strong vent that sucks air out and vents to the roof of the building). Here are some longer shots to set the scene. These correspond to the areas in the close-ups in the first post.
When you say "rip it all out" do you mean the all of the tiling? Or just the trim pieces?
There is no recess (hopefully that is clear from the newer pictures). What is the concern about mold?
stuvwxyz99 12-10-2012 08:26 PM
Thanks for the post. I have some questions so as to understand better what to do, and why I am doing it. Should the line be along the border of the tile and the grout? How deep and what is the purpose of this line?
Do I lay the bead along the middle of the grout, between the wall and the tile? And the wiping is intended to spread it out to cover the entire surface of the grout, is that right?
So, the paint meets the tile and the (caulk-covered) grout is "invisible", correct?
