Advice Needed On Paint Prep... - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-11-2009, 04:25 AM   #16
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Kilz has a strong Oder and will make you a little dizzy ,
A little dizzy, in a closet?
How about dead.
If you just get in there and scruff up everything and use the Fresh Start, you will be fine Do NOT use the Kilz2( JUNK)
Just remember that it along with your finish coats( latex) can take 30 days to cure to their intended hardness.
Old 09-11-2009, 07:32 AM   #17
How about dead.
It takes less than 10 minutes to paint a closet. If you are going to be dead in that short amount of time, then maybe YOU shouldn't have been there in the first place.....But hay I'll give you points on DRAMA !
LouLewyLewis is offline   Reply With Quote
Old 09-11-2009, 07:55 AM   #18
Matthewt1970's Avatar
Rewards Points: 1,098
Kilz oil won't kill you in 10 minutes, but it will knock your head around a bit. There are a lot of quick drying oils on the market right now and since it won't be soaking into bare wood, the quick dry will be fine. Kilz Oil is a stain blocker and a brain eater so don't use that unless you have some stains to block.
Old 09-11-2009, 10:43 AM   #19
Rewards Points: 28
Ok, BM Fresh Start latex primer it is then. Of course over a thoroughly sanded and TSP'd surface!
myke232 is offline   Reply With Quote
Old 09-11-2009, 12:50 PM   #20
Tools-For-The-Trades
Send a message via Skype™ to Ladderpouch.com
All good advice. If you are worried about the odor of the Kilz - there are also low odor oil primers eg. Sherwin Williams Preprite and Ben Moore Fresh Start. I agree with Lou about the preference of using the oil primer. Good Luck!
Ladderpouch.com is offline   Reply With Quote
Old 09-11-2009, 02:47 PM   #21
chrisn's Avatar
Rewards Points: 122
Did you notice the laughing smilie ? That indicates that it was a joke.Maybe YOU have been in the Kilz too long?
Old 09-11-2009, 07:19 PM   #22
That's great you have made your decision , with time and patience I know you will get the results you worked so hard for. And be able to put closure on this project. Good luck....
Old 09-12-2009, 05:45 AM   #23
chrisn's Avatar
Rewards Points: 122
Be sure, and this is very important, be sure, you have rinsed the tsp, at LEAST 2 times with clean water.
Old 09-12-2009, 11:36 AM   #24
Rewards Points: 28
Thanks guys! Drywall prep is going well in the rest of the room so hopefully I'll be priming soon!
Old 09-12-2009, 11:44 AM   #25
BTW KIlz makes an odorless oil primer
jongordo8 is offline   Reply With Quote
Old 03-18-2012, 09:12 PM   #26
TSP Rinsed?
I just got done TSPing my entire living room; took me the better part of a day. It has a sloped ceiling that that is almost 18' at the crest and 15' at the ends. I used a 12' step ladder, a sponge mop for the TSP, and a sponge mop for fresh water. I only rinsed once (but kept the rinse water clean) Questions: how can I be certain that all of the TSP is rinsed off? What will happen if I didn't?
lkstaack is offline   Reply With Quote
DIYer looking for advice on paint spraying unit107 Painting 13 08-17-2009 10:32 AM
DIY Exterior of House Paint Job: Need Advice jamesp880 Painting 6 02-01-2009 11:56 PM
I think I was stiffed by a Paint Contractor. Any advice? Shaun_in_NC Painting 4 09-28-2008 09:13 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Paint color advice needed chrisd90 Interior Decorating 6 05-18-2008 02:33 PM
