Advice Needed! - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2011, 05:19 PM   #16
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by MandyB13 View Post
Is it possible they just attached the drywall to the original plaster wall?
Yes.
The wall I posted pics of it now drywall free, but I am scared to rip down the rest of it. Does anyone have any advice?
Your scared to rip down the plaster?
It's is messier than drywall, but there will still just be studs behind it that you can re-attach new drywall to. Likely over wood lath strips. The plaster will break off. The wood lath is excellent kindling.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-25-2011, 05:33 PM   #17
DIY'er
jamiedolan's Avatar
p.s.
Save your lungs while removing the plaster:
Link to mask on Amazon - I've also seen this brand locally.This is the one I use.
Also; Highly recommended that you buy one of these filters for the shop vac your using:
I have one for my Ridgid and my ShopVac. They last a very very very long time and work very well for tiny dust particles.
ShopVac Cleanstream Filter
Ridgid Cleanstream Filter
They have them at HomeDepot for Ridgid.
Old 02-25-2011, 06:51 PM   #18
Good idea on the mask, we've been using other masks but I don't think they are working that well. I just started taking the paint off of the door frames and at least the wood underneath it is nice. It appears to be pine, is that a common wood used in door frames in the 1920's?
On a side note, I guess breaking down some drywall knocked an already worn out pipe lose from under the sink...had to have the handyman come fix it this morning.
MandyB13 is offline   Reply With Quote
Old 02-25-2011, 07:28 PM   #19
We live in Reading, PA.
Old 02-26-2011, 09:24 AM   #20
Matthewt1970's Avatar
Rewards Points: 1,098
That's drywall. Anyone else notice it's on backwards?
Old 03-02-2011, 09:32 AM   #21
Originally Posted by anderson111 View Post
I thinks you have to paint all these walls very neatly and it requires moistures in the home.
Tags
paint stripping , unknown wall texture
Double Door Alignment Advice Needed Lovegasoline Building & Construction 6 12-15-2009 02:32 PM
Needed basement advice... gripp2020 HVAC 4 11-29-2009 12:43 AM
Home electrical advice needed jiminy Electrical 11 12-14-2007 04:13 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
