Old 04-22-2009, 03:38 PM   #1
Unhappy
Advice on basement waterproof paint
We recently had a small mold problem in one of our crawlspaces and decided to install french drain in both our crawlspace as well as the basement. The walls are cinderblock and the company which did this project did a poor job of painting the thoroseal on the walls. We did not notice this till everything dried out and our walls look patchy now.
I wanted to paint it with UGL Drylok latex but after a little bit of research found out it would not help me as I already have thoroseal on the wall. I was also considering Behr waterproof paint as someone on a forum mentioned that as this was acrylic and not latex, it can still be used on top of thoroseal.
What do I do?? This is so confusing...please help!!
shaan71 is offline   Reply With Quote
Old 04-22-2009, 05:31 PM   #2
What type of thoroseal was used? This is from the thoroseal website.
In general, no, we do not recommend painting over Thoro coatings. ThoroSeal Waterproof Coating ® and ThoroSeal Foundation Coating ® should never be painted over. ThoroSeal ® Waterproofing Paint may be painted over, but wait at least 30 days to allow a full and complete cure, and then use latex paint only. Super ThoroSeal ® should not be painted over – painting voids the product warranty.
Old 04-23-2009, 07:39 AM   #3
The previous owner had some type of waterproofing paint on, which was followed by the said patchy Thoroseal. I don't know what type was used. Can I follow it up with more Thoroseal? If so, what type?
Old 04-24-2009, 06:04 AM   #4
I'd say get in touch with a basement water proofing specialist to get the job done.
one such company is www.waterproofingpa.com, they give free consultation and have basement waterproofing specialists with them.
Dana
Dana11 is offline   Reply With Quote
Old 04-24-2009, 06:58 AM   #5
Thanks a lot for both the responses!
Tags
basement, paint, waterproof
More On This Topic
Learn about texturing your wall before faux painting, in this free video. Read More »
Learn about proper heights when building a walkout basement in this free home improvement video. Read More »
Latex is one of the most versatile paints available. One vareity is vinyl based, which dries quickly and has a priming feature. Acrylic-based latex paints provide the toughest finish for durability and washing. These also have a drying time of just one... Read More »
Make sure you know what code requires when framing bearing walls. Learn about framing bearing walls when finishing a basement from a professional remodeler in this free home improvement video. Read More »
There are various kings of beads that you can use on your drywall. Learn how to bead dry wall when finishing a basement from a professional remodeler in this free home improvement video. Read More »
Basement Cooling advice fdb HVAC 4 04-10-2009 03:25 PM
Advice for choice of basement flooring dgates Flooring 8 09-29-2008 12:47 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
I'm scared to paint our front door! Advice for good results??? Beth777 Painting 16 07-25-2008 12:25 PM
waterproof basement floor?? patnshan Remodeling 3 09-07-2006 02:58 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
