Advice about deck & siding stains
The warranties are marketing and have little to do with the quality of the product
I can say from personal and professional experience the Behr stain products are particularly poor
Ben Moore does make an acrylic ("latex") solid as well as an alkyd (oil) solid
Either one is miles above the Behr
"Easier water clean-up" is sort of misleading
With the solvent clean-up of alkyd based products the process (clean-up) is in fact the basically the same
The biggest difference is the tools used in solvent based products use pints worth of solvents to clean (and arguably clean up better), and the acrylics use gallons and gallons of water
The second biggest difference is in most places the pints worth solvent can not be poured down the sink
However, it can be saved, the solids will sink to the bottom, and it can be re-used
I find the actual time and ease of clean-up (aside from the saving of old solvent) for oils is actually less
