Adhesive Remover From Drywall - Painting - DIY Chatroom Home Improvement Forum
Old 05-12-2010, 12:20 PM   #1
Adhesive remover from drywall
OK people - give it to me straight. What is the best product for removing glued on paper crap from drywall. My son used Gorilla glue to stick things on the ceiling and we need to get it off.
bmt1970 is offline   Reply With Quote
Old 05-12-2010, 04:01 PM   #2
Rewards Points: 252
This is the post where the belt sander might come in handy! Gorilla glue does not come off easy, on drywall you will certainly peel the paper facing off while trying to take off the gorilla glue. I would probably use a small razor knife to score around the glued areas and "peel" the drywall paper face off, then prime with Guardz, skim coat with some joint compound, sand, another coat of guardz, then paint.
Keep the kids away from the Gorilla glue!!
mazzonetv is offline   Reply With Quote
Old 05-13-2010, 04:31 PM   #3
Household Handyman
Rewards Points: 1,408
We had a similar problem with some border paper my daughter put up at the top of the walls of her room. Of course when she left home, she did not take this with her. It seems she used something like yellow 3-M adhesive to put this border paper up. We eventually tried "Goof Off" ( I think that was the name). This did not readily remove the glue but wetting it with this stuff made it so we could sort of "roll" it off and did not have to remove the paper surface of the drywall. Two coats of primer and two coats of paint finished it out. David
Old 05-13-2010, 06:10 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
If it were a different product I'd have more suggestions, but for that stuff it's a chisel and/or sander
Sorry
slickshift is offline   Reply With Quote
Anyone have any experience with Citrus King adhesive remover? skipjack Remodeling 6 03-29-2015 11:26 AM
Adhesive removal from drywall JoeU Drywall & Plaster 4 02-17-2010 04:43 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
