Adding Wood Gloss - Painting - DIY Chatroom Home Improvement Forum
Old 11-25-2009, 11:24 PM   #1
New to DIY
Adding wood gloss
Hi, i am working on something at the moment. I was just wondering: When i go to paint my thing which is made out of wood by the way, how do you make the painted wood look shiny or glossy?
Sunjae is offline   Reply With Quote
Old 11-25-2009, 11:57 PM   #2
Too Short? Cut it Again!
How shiny/glossy? How big is what you are building? Are you planning to use water based or oil based paints? Do you have the choice where you live?
Old 11-26-2009, 02:37 AM   #3
New to DIY
Transparent sort of shiny/gloss. I am painting something small and using waterbased paint.
Old 11-26-2009, 04:28 AM   #4
Did you prime first? What have you put on so far and do you have time to let it dry? Is this a school project?
If it is small and you primed the wood, and you put nice artist color over the primer, you should be able to seal it fairly soon with a clear coat.
If you used household paint, you will have to wait a bit for it to cure before you mess around too much.
If your wooden thing is portable, you can always do what I used to do when once an aspiring industrial designer (and still do now when I need a high gloss finish). Sneak the thing off to the auto body shop nearest you and have them clear coat the thing with as many layers as you think you need.
The guys/gals can usually be bribed with a few $$ to do this while they are working something else, especially if it is small. In my opinion, next to the crazy people who spray expoxies, car and boat people still deliver the highest gloss finishes on the planet.
Old 11-26-2009, 07:29 PM   #5
New to DIY
It's actually a home project and i am using household paint. I think it is small enough to be portable.
Old 11-30-2009, 06:44 AM   #6
If you have used household paint, like a semi-gloss? You should let it cure for 30 days or so. If this does not dry to enough gloss? Try putting on a coat of acrylic polyurethane. If you did not prime the wood? I hope you do not need this finish to last long.
Tags
gloss , shiny , varnish
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Been looking at some Wood Burning Stoves SELLC HVAC 17 10-20-2009 09:06 PM
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 09:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
