Add Texture Ceiling To Completely Finished Room. - Painting - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 09:47 AM   #1
Rewards Points: 384
Add texture ceiling to completely finished room.
What's the cleanest way to do this? Our finished basement has an ugly poorly done drywall job so I want to add some texture to hide it. What's the best way I can do this without moving everything out?
RyanD is offline   Reply With Quote
Old 04-01-2010, 08:28 AM   #2
How "ugly" is the ceiling? Texture hides a lot of faults, but not all of them. You might consider going back and dressing up the ceilings with a top coat of compound to smooth everything out. It's amazing what a pro can do with a mud box.
What kind of texture are you considering? Do you think you will be spraying on the texture or hand applying it? How big of an area are you considering doing? How much help will you have at hand?
Trying to focus on the ceiling during a texture job means you shouldn't have to worry about trip hazards around your feet. Move everything out of or to one side of the room, texture the empty side, quickly have you helpers move everything to the finished side and continue to finish the remaining ceiling before the edge of your texture starts to dry or you will see where you stopped and started the halves. Be sure to cover your flooring under your work. Expect some splatter on the adjoining walls.
Ron Franck is offline   Reply With Quote
New ceiling within an existing room? Is it possible bennett12 Building & Construction 3 07-10-2009 09:05 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
Matching Ceiling Texture WorkOnIt Painting 7 05-14-2007 09:46 AM
