-   -   acrylic over oil problems (http://www.diychatroom.com/f4/acrylic-over-oil-problems-185501/)
gulleyj 08-18-2013 02:02 PM
The funny thing is that I am still surprised to be surprised by the dumb things I can do…
The situation: a kitchen wall with a window over a counter with a sink and cooktop. Less than 50 sf of surface. The wall was painted with an off-white, satin finish, oil-based paint ten years ago and the paint film was in perfect condition. The client (my elderly Ma) wanted the wall to be a cheerful leaf green color and because she has respiratory issues, needs to use the kitchen asap and could not vacate, I decided to repaint with an acrylic (a semi-gloss enamel made by Benjamin Moore) using lots of exhaust ventilation.)
I washed the wall with a 50/50 water/ammonia solution and sanded it with 150 grit on a drywall pole sander. Then I washed it again with a product called Liquid Sandpaper and let it dry/evaporate for an hour. Pretty thorough, thinks me, but then comes the brain cramp.
Instead of a primer I go straight at it with an acrylic eggshell. What was I thinking? Well, the wall will need at least two coats to go from white to middling green, so the first coat doesn’t need to have the final, semi-gloss, so let me just use this paint I already have that matches the final color almost exactly. Now of course this first treatment scratches off with a fingernail after 100 hours of curing. What to do?
Do I need to sand/scrape off all the green paint? Or will a coat of BIN Primer “sandwich” this layer firmly to the wall?
Jmayspaint 08-18-2013 02:28 PM
Once there is a non bonded coat on a surface nothing will 'fix' it except removal of that coat.
Oil priming and top coating again may improve the problem some, but the film will still scratch off.
ToolSeeker 08-18-2013 03:05 PM
I really think the Liquid Sandpaper is causing your problem. NASTY STUFF!
chrisn 08-18-2013 04:44 PM
100 hours? of course it is going to scratch of, so just don't do it till it fully cures, 3 weeks at least and you should be fine
cdaniels 08-18-2013 06:11 PM
With the prep you did you should be fine once it has completely cured.Would a bonding primer have been a better first coat?Of course but the sanding should take care of bonding issues once it is cured.
