603 Wallpaper Removal Solution - Painting - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 09:02 PM   #1
Rewards Points: 45
I got lucky and I can simply peel the wallpaper off the walls in my new home (for the most part). Need to wet down some of it but it's all off now.
Now I just have to deal with the adhesive.
Would 603 be ideal for simply removing wall paper adhesive if I already have the wallpaper off the walls or is it more for removing the actual wallpaper itself? I think I read about this stuff on the forums here but I'm not 100% sure.
Or - I have seen recommendations to simply use fabric softener mixed w water to remove the adhesive.
Which would you guys suggest?
Thanks!
Dan
dschribs is offline   Reply With Quote
Old 05-07-2013, 10:13 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Yes to all the above. Nothing is going to make it effortless. I use water and timing. I find most the additives are for people who think it will go quicker. It goes with effort and timing.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-07-2013, 10:30 PM   #3
It's my understanding that the additives, enzymes, break down the cellulose molecules, turning them from sugar to their component parts easier to wash off.
The Following User Says Thank You to jsheridan For This Useful Post:
chrisn (05-08-2013)
Old 05-08-2013, 04:07 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
He got it^
read this and or ask Mike
http://www.safeandsimple.com/
chrisn is online now   Reply With Quote
Old 05-08-2013, 04:08 AM   #5
chrisn's Avatar
Rewards Points: 228
also, Diff works, but is kind of toxic
The Following User Says Thank You to chrisn For This Useful Post:
ToolSeeker (05-08-2013)
wallpaper directly on drywall best removal SuzanneCD Drywall & Plaster 3 11-17-2012 05:20 PM
Wallpaper removal & brown paper backing _alphaBeta_ Drywall & Plaster 4 09-10-2012 09:26 PM
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 04:30 AM
Wallpaper removal or primer? Should I put up new wallpaper instead? Aqua Painting 1 04-06-2011 05:36 AM
Wallpaper Removal saggdevil Painting 1 06-01-2009 05:31 AM
