45 Degree Taping - Painting - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 11:55 AM   #1
retired guy
igneous's Avatar
Rewards Points: 137
45 degree taping
I have to fix a problem spot on a 45 degree ceiling joint. The tape is coming loose, but only in a two or three ft. section. I intend to cut out the bad spot; mud in some joint compound, tape, etc. My question is how can I be sure to keep the same joint line from wall to wall? A corner trowel is for 90degrees, so that won't work. Is it pure patience and skill? Just askin.
igneous is offline   Reply With Quote
Old 09-06-2011, 12:46 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Kind of. Since you're just doing a small section , that's about it. If you have a 6' straight edge or even a straight piece of trim or something, you could hold that on the line to see how you're doing.
If you were doing the whole run, you could get this flexible corner tape that has plastic embedded in it to keep it somewhat rigid for odd angles.
It would be at a pro drywall store, but I think HD has something like it.
Brushjockey is offline   Reply With Quote
Old 09-07-2011, 05:02 AM   #3
m1951mm's Avatar
I agree with Brush, it is patience and adding layers of joint compound until you get a line that looks good to you. I have never seen a pro drywall person use one of those 90 degree knifes. I have only seen the flat 6" blades used. Spread your compound on both sides of the angle, fold your tape in half and smooth in the tape at the ceiling and then the wall in seperate passes which may pull out some of the compound, and that is ok. Let it dry then work only one side of the angle at a time, i.e. do a coat on the ceiling and let that dry and then do the wall side of the angle (repeat till it looks good). I find it extremely difficult to get both sides of the angle smooth at the same pass.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
72 degree vent air 75 degree return air ryanxo HVAC 20 06-09-2011 04:49 PM
135 degree crown molding cut jbeaulieu Carpentry 5 05-19-2011 04:30 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-21-2010 11:53 PM
Taping suggestions misfitz Painting 1 07-02-2009 07:26 AM
90 degree turn in horizontal 3" main drain wildbilly Plumbing 2 03-14-2009 05:52 PM
