311 Or 411 Tip For Doors????? - Painting - DIY Chatroom Home Improvement Forum
Old 03-03-2009, 12:05 PM   #1
311 or 411 tip for doors?????
Spraying interior doors with SW Pro-classic waterborne and want to see what tip is better for the job. Also SW says NOT to thin down the pro-classic, it can be sprayed with a .011 tip....any thoughts?
ffgreg is offline   Reply With Quote
Old 03-03-2009, 12:06 PM   #2
My sprayer is a Wagner 9150 3000psi unit.
Old 03-04-2009, 07:11 AM   #3
its up to you .The only difference is the fan size. I prefer the larger fan myself
torpainter is offline   Reply With Quote
Old 03-05-2009, 08:57 PM   #4
pro-classic
I worked with pro-classic water borne today. It is a beast to work with. I like the 415 tip. I put a little floetral in the paint before I spray. 415, move a little quicker. Keep a mohair 3/16 nap roller with you. Pro-classic sometimes sags. A smaller tip works ok but the room fogs up a little too much. Also wear your resperator!!!! That stuff is brutal on your lungs.
DGideon is offline   Reply With Quote
Old 03-09-2009, 07:20 PM   #5
Used a 413 tip and DID NOT thin the SW Pro-classic......Finish was awesome.
