2nd Coat On Walls - Painting - DIY Chatroom Home Improvement Forum
Old 05-23-2009, 08:47 AM   #1
Haste Makes Waste
2nd Coat on Walls
When applying 2nd coat on walls, is it necessary to do all the cut in work again, or just roll as closely as possible.
This room is large with 10-12ft ceilings, 3 single doors and a double french door, 3 bay windows and a mantle/fireplace. LOTS of cut in work.
saggdevil is offline   Reply With Quote
Old 05-23-2009, 08:57 AM   #2
I think if you don't put a second coat on the cut-in, you'll notice it. I never seem to get a good enough coat on the first time to not do a second coat. And me personally can't get as close to the joint with a roller as I've seen others do. And as we all know, if we skip a step, we'll regret it later.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 05-24-2009, 07:44 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
You really should cut in again. You don't have to be as exact with the cut line, but make sure you are covering any areas areas where the old color is showing through.
How to Skim Coat Walls LeahMia1995 Remodeling 2 03-07-2008 01:25 PM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
finish coat over painted walls a_theater_god Remodeling 2 07-30-2006 10:27 PM
