2nd Coat Timing - Painting - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 07:29 PM   #1
Rewards Points: 1,062
Question
2nd coat timing
what is the best timing or better said state of the 1st coat of paint on top of which to apply the 2nd? is it better to wait for it to completely dry or should it still be kind of wet a little or somewhere in between? i think timing is not a good measure because it is contingent on the temperature and humidity levels.
thanks
Old 02-22-2012, 07:42 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Reading what it says on the can is a real good starting point....
Dry is good. A little wet is not. Does not need to be "cured"- that could be several weeks.
Funny question- why do you ask?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
amakarevic (02-22-2012)
Old 02-22-2012, 07:46 PM   #3
Too Short? Cut it Again!
Generally speaking you do not want to put a second coat on something that is still tacky. You risk pulling the first coat off on to the roller or at the very least screwing up the adhesion between the two layers. At worst, you could prevent the first coat from at least surface drying properly. If it is cool and or humid, you just have to wait it out. As mentioned, the directions on the can are a good reference point.
The Following User Says Thank You to user1007 For This Useful Post:
Old 02-22-2012, 07:48 PM   #4
because i need to apply a 2nd coat ... LMAO
glad you find it amusing
Old 02-22-2012, 08:08 PM   #5
Ok- how about telling us something- like what exactly you are using.
And if you are in a hurry- fans help alot.
oh- over 1500 posts- I think this is called..fishing!? lol
Old 02-22-2012, 10:20 PM   #6
Old 02-22-2012, 11:05 PM   #7
Rewards Points: 626
about four hours to wait to star the second coat.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
amakarevic (02-23-2012)
Old 02-22-2012, 11:29 PM   #8
C'mon Joe- fishing - you throw a line out, hope someone bites...
Old 02-23-2012, 03:55 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
like trolling
chrisn is online now   Reply With Quote
Old 02-23-2012, 06:03 AM   #10
I live in a fishing resort. I'm reminded all day every day of fishing and boats. I was looking for an alternate meaning, an internet one, like trolling. It's Occam's Razor, the simplest answer is usually the correct one. I guess.
Old 02-23-2012, 09:08 AM   #11
Gymschu's Avatar
Rewards Points: 486
It depends.........when you do this professionally sometimes you have to stretch the boundaries. Personally, I really like to wait 24 hours. That gives you plenty of time for a proper drying time regardless of humidity, heat/cold, etc. Now, I have had to use artificial means to get that first coat to dry so I could quickly apply a 2nd coat. Using a high-powered fan accomplishes this goal. I can recall no problems doing this even though I don't (professionally) recommend it. I "cheat" a bit on some projects where time is of the essence, or, I'm on a small job 40 miles from home and don't want to have to drive back again the next day to finish.
Old 02-23-2012, 05:37 PM   #12
chrisn's Avatar
Rewards Points: 232
Thats deep
Old 02-23-2012, 05:50 PM   #13
Yes, much deeper than my simple explanation. Check it out.
Old 02-24-2012, 04:21 AM   #14
chrisn's Avatar
Rewards Points: 232
Oh, I always check out what I know nothing about
Old 02-24-2012, 07:47 AM   #15
As Sheldon Cooper would ask, Sarcasm?
Stucco: Is it better to use 1 coat of of finish coat throughout or 3 coat system? psubaron Building & Construction 5 10-06-2011 08:48 AM
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 07:30 PM
partial second coat - did I mess up? matt_ Painting 5 09-22-2009 07:17 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
