2nd Coat: Sheen Change Possible W/o Need For 3rd - Painting - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 03:22 PM   #1
Rewards Points: 89
2nd coat: sheen change possible w/o need for 3rd
Quick question (probably a dumb one): I don't like really shiny trim so I went with BM Regal Select in Eggshell (I like SW's satin sheen for trim). I do not understand how that is their 3rd level of sheen in that line, because it has almost no sheen at all (Zin 123 has more sheen). Trim and doors definitely need a second coat, and I'm thinking for the next gallon I will just get the pearl sheen (next one up).
I know it's a dumb question because I'm sure I won't get perfect coverage for the second coat (just like I didn't for the first) and would be left with sheen bleed-thru (if there's such a term) and the desire to 3-coat it.
But you have to ask dumb questions once in awhile...
7.62 is offline   Reply With Quote
Old 05-13-2013, 04:25 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
BM and SW have same names for different things.
SW 's satin = BM's Matte
BM's Satin is actually the sweet spot for trim. A little under a Semi- more than an egg.
I thing Regal Select Egg is a fine wall paint, i wouldn't use it on trim. And all sheens are really a range, not an exact thing, and RS egg comes in at the lower end of that range ( which is why it's great for walls).
I just used SW Duration home satin today- I'm surprized you like that on trim. It also has very little sheen, like i said = BM matte.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-13-2013, 04:58 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
I'm confused
Old 05-13-2013, 05:03 PM   #4
No surprise there CN!
Old 05-13-2013, 06:52 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
If your having coverage problems, try putting the paint on thicker. Regal is great paint, should have no problem changing sheen in one coat. The thing is its hard to get a full "coat" of paint on in one application. Even a lot of pros I know have to do two applications to get the film thickness of one "coat" that is recommended by paint manufactures.
Jmayspaint is offline   Reply With Quote
Old 05-13-2013, 07:21 PM   #6
Rewards Points: 89
It's all a preference. I just don't like super shiny trim.
I would have to disagree with you on the terminology, at least where BMRS is concerned. It comes in five sheens: flat, matte, eggshell, pearl (probably equal to their satin in other lines) and semi. Eggshell is farther up the sheen line than matte and has MUCH less sheen that SW ProClassic (or Duration for that matter) in Satin. So SW's satin definitely has more shine than BM's matte (at least where RS is concerned).
Regardless, I am wondering what my results will probably be with using the next sheen up for the second coat (same paint [BMRS] in the same color). Will I likely have areas where the sheen will be uneven? I absolutely do not want to do three coats, so if the sheen will likely be uneven then I will just pick up another gallon of the eggshell.
Old 05-13-2013, 07:25 PM   #7
Rewards Points: 89
I find that it does not level very well at all. I found that brush marks are very apparent if you put the paint on too thick. Plus, I find it difficult to put the paint on but so thick when doing windows, fireplace mantles and other more intricate work.
But I'm a little confused by what you are saying. You say 1) that I should have no problem changing sheens in one coat, but that it is also hard to get one full coat on in one application.
This is a really, really big job. I am doing the second coat regardless. I want to up the sheen a little, but not if doing that will require a 3rd coat.
Thanks guys!
Old 05-13-2013, 08:35 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
One thing that helps me get on a thicker coat is using a good quality brush with softer bristles.
The softer the brush is, the more paint it will leave behind as you brush. So you can still brush it out some and not thin out the coat so bad.
Actually, a thicker coat can flow out smoother, and with less brush strokes if you can get it on evenly and pretty quickly. I have the best luck getting a smooth coat on trim by using a 4' roller to get the paint on the trim then brushing it out with a brush. But you gotta be quick.
Old 05-14-2013, 04:38 AM   #9
chrisn's Avatar
Rewards Points: 312
You're a big help
Old 05-14-2013, 07:17 AM   #10
Rewards Points: 89
Well I got the Pearl sheen this morning for the second coat. Got there late (7:05) and thought I'd be in a long line. I was the only one there.
We'll see how this goes!
Oh - Jmayspaint, I was using the Purdy Nylox brushes most of the time on the trim. Very soft bristles. But I used a standard medium stiff Purdy 3" brush on the wains b/c it's all I had. I picked up a Wooster Silvertip in 3" at BM today because the bristles seemed very soft. It was a very inexpensive brush but seemed to be pretty nice.
Old 05-17-2013, 06:22 AM   #11
Rewards Points: 4,796
BSW 's satin = BM's Matte
Not sure what you mean here. Let's say comparing SuperPaint in Satin to Aura in Matte, SuperPaint has more sheen.
jeffnc is offline   Reply With Quote
Old 05-17-2013, 07:12 AM   #12
But SP satin is way less sheen than Aura Satin.
My point is that it is closer to , maybe = was the wrong way to put it.
Bm 's sheens are not exact in the same catagory even between its own lines .
Hardwood refinish questions, removing part of old coat only before re-coating? Dimeron Flooring 2 05-17-2013 07:54 PM
Need advice using Insl-x Cabinet Coat ladydub Painting 13 06-29-2012 03:22 AM
Please help (again):Why is my SW Pro Classic paint sagging on the second coat? Fun2Learn Painting 7 12-05-2011 10:12 AM
Cracks in stucco scratch coat - is this normal? chadurban Building & Construction 5 05-25-2009 10:55 PM
do I have to sand my first coat of semi-gloss on ceilingbefore I apply the 2nd coat? newbpainter Painting 6 04-07-2009 09:01 PM
