2nd Coat Primer - Painting - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 06:39 PM   #1
Rewards Points: 874
2nd coat primer
Have to apply another coat of primer due to an added skim coat and light sand. Does the entire wall need to be primed because, if not, then wherever I start and finishing will leave a line? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 04-25-2013, 08:14 PM   #2
Gymschu's Avatar
Rewards Points: 668
No need to reprime the whole wall. Just prime the spots you repaired. Your finish coats will take care of any lap marks in the primer coat.
Gymschu is online now   Reply With Quote
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
ltd (04-25-2013), user1007 (04-26-2013)
Old 04-26-2013, 01:53 AM   #3
Primer doesn't need to look good. It's only meant to help the color coat bond to whatever you're painting, and needs to completely cover the old paint without drips or other uneven texture. And usually second coat of primer not necessary. But if you really think that you have to apply another coat of primer. You may use Zinsar 123, that stuff covers everything. Or you may just prime only on the spots, you want to repair.
timkitchen is offline   Reply With Quote
Old 04-26-2013, 07:56 AM   #4
Rewards Points: 5,974
A lot of people think primer should look like paint when dry this is not true. When primer dries it is streaked, has lap lines, and really looks like some kid painted it. So then they add an unnecessary second coat to try and make it look good. But this is how primer is supposed to look.
Old 04-26-2013, 08:12 AM   #5
Too Short? Cut it Again!
Agree with all. You do not want to leave physical highspots from not feathering out your roller work in the primer layer though. Those will show. More so as you increase sheen in the finish coats.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Skim Coat over Primer cougar01 Painting 25 07-03-2012 12:43 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Primer - even coat needed? DaveSD Painting 7 05-10-2010 03:40 PM
Painting over 4 year old primer coat flyfisherman Painting 5 01-06-2009 06:51 PM
