2nd Coat Help - Painting - DIY Chatroom Home Improvement Forum
Old 06-23-2013, 09:43 PM   #1
Rewards Points: 85
2nd coat help
Hi There. Primed and put first coat on new construction drywall in basement. We are using Sherwin Williams drywall primer and Duralast or Durabond or whatever they call it paint.
After looking at the finished results, there is a wall parallel to where you enter the basement, so coming into the basement you are looking down the wall. As I looked at the finish in the afternoon sun through the window, I could see roller marks on the wall where you can see differences in the finish.
When I do my second coat, what can I do to avoid those marks and get a nice even finish on the walls? Thanks for any advice.
joshs is offline   Reply With Quote
Old 06-23-2013, 10:00 PM   #2
Gymschu's Avatar
Rewards Points: 838
Lots of threads on here about proper finishing techniques.
#1 Use at least a 1/2 inch nap roller sleeve so you can get plenty of paint on/in the roller. Load that puppy up with paint, don't be stingy. It should almost be dripping when you remove it each time from your roller tray.
#2 Don't push! Let the roller do the work. Most noobs push down too hard on the roller which then pushes paint out to the sides leaving roller marks. Be gentle but firm as you roll..........
#3 Use quality tools. That pack of bargain roller covers is virtually worthless. Get Purdy or Wooster brand.
#4 Use quality paint from Sherwin-Williams or Benjamin Moore. Never heard of DuraJunk paint. Switching away from SW after using their primer sure didn't help.
#5 No paint covers in one coat. That second coat will cover lots of mistakes and will even out the color and the sheen.
#6 Hopefully you had some good drywallers. If not, some of those problems could be caused by a poor drywall finish job.
The Following User Says Thank You to Gymschu For This Useful Post:
Jmayspaint (06-23-2013)
Old 06-23-2013, 10:02 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
When you roll the wall, make all your finish strikes down strokes.
One major reason for 'flashing' like you describe is textural differences from where the roller was going up, an where it was going down.
Put plenty of paint on the wall, spread it out quickly, and finish with down strikes. (Or up strokes, just easier to go down.)
The thing is, you can easily over tool fast drying latex, like Duration, so keep your strokes to a
Minimum, while still spreading it well.
Over tooling is another major reason for flashing.
Also, make sure the paint is stirred/mixed well.
Sanding and dusting the wall before the finish would also help.
Walls with that kind of light are tough, good luck!
Jmayspaint is offline   Reply With Quote
Old 06-24-2013, 05:54 AM   #4
Too Short? Cut it Again!
All as above. Work from wet areas to dry ones, not the other way around.
Remember the higher sheen the paint, the more surface differences and defects will show.
Higher sheen latex paints take up to 30 days to cure so do not be too quick to judge the final coat.
Old 06-24-2013, 07:59 AM   #5
Rewards Points: 85
Thanks guys. Using an egg shell sheen. First coat didn't look awful just want to make sure it looks good. Thanks!
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 01:55 PM
Stucco: Is it better to use 1 coat of of finish coat throughout or 3 coat system? psubaron Building & Construction 5 10-06-2011 07:48 AM
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 06:30 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
