1st Time Painting, What Should I Know? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-25-2010, 09:30 AM   #16
a week is a long time. if you leave it and do your final coats razor knife edge before removal or you will lift wall paint
Old 01-25-2010, 09:37 AM   #17
Remodeling Contractor
Since you will be leaving the primer on for some time I would remove the tape. Normally you remove the tape within 20 minutes
Old 01-25-2010, 05:41 PM   #18
VP Queen
Plaster Ayn's Avatar
Its all in the prep work. Take more time than you would like on the taping. Make sure your tape is one straight line as opposed to jagged. A good paint job is always judged on its edges.
Plaster Ayn is offline   Reply With Quote
Old 01-26-2010, 12:01 AM   #19
Agreed take your tape off while your paint is still tacky not wet. I would recommend to get a quality brush (Purdy, or Wooster) and try cutting in with it on an in conspicuous spot, it might work out for you and you wouldn't have to tape again. I hate taping because of all that work putting it on and if you have just a little bit of sweep-age it is ruined. Practice makes perfect. While cutting in keep firm pressure on the brush, be generous with your paint, follow the bead at the end of your sash, and always keep your brushes and roller wet, never paint until their dry.
Soup
campbell804 is offline   Reply With Quote
Old 01-26-2010, 12:49 AM   #20
Exotic NooB
You could just avoid the tape and use a straight edge Like a six inch putty knife and a small flat hogs hair bristle brush (Size 12 or 14.) It takes longer to paint, but not as long to tape, re-tape...
I'm a purist when it comes to painting. I use a brush and I paint in the nude so that I am one with the wall. It also helps to keep paint off of your clothing. I sometimes use two bushes and approach the wall in the crane stance and pretend that I am the Karate Kid.
Be sure and stock up on beer before you paint because it is a real hassle to get dressed and go to the store if you are tapped out. Nothing like running out of something to drink while you are working.
inlikeflint is offline   Reply With Quote
Old 01-26-2010, 04:10 AM   #21
paper hanger and painter
chrisn's Avatar
Rewards Points: 296
I think you hit the beer a little too hard
Old 02-02-2010, 02:06 PM   #22
Rewards Points: 77
Painted the room this weekend and turned out pretty good, however, there are a few spots that need touching up. Some minor spots where you can see a bit of white primer but not very noticable if you don't know where to look.
I am worried about touching up. It seems as simple as just a quick stroke of a brush but I am concerned about it not blending in properly and looking blotchy. Not sure it will come out like that but that's my worry right now.
elementz is offline   Reply With Quote
Old 02-02-2010, 04:35 PM   #23
Sounds like everyone has about answered you questions on what you will need for your project. Once you have visited a paint store though (make sure you take notes), hop online and check out this site (www.hardwareworld.com) to see if you can find the brands and supplies any cheaper. I have been using the site for a LOT of my DIY projects and have had nothing but success w/them. You just can't beat their prices. Good luck and happy painting!!!
DecoratingDiva2 is offline   Reply With Quote
Old 02-03-2010, 01:44 PM   #24
Rewards Points: 77
Thanks for the post but I have already painted as my previous post said and am looking for further advise.
Old 02-03-2010, 01:48 PM   #25
use a roller if you rolled the walls, not a brush. But minor touch-ups will blend in fine after it dries. Did you use Behr paint? That would explain why the need for touch-ups. Did you paint with two coats?
Old 02-03-2010, 05:23 PM   #26
touch up will depend on the sheen of the the paint you used.
Flat should be easy.
others may require corner to corner to get it right.
As advised above... painting in the nude is the best way...post pictures...
Big Bob is offline   Reply With Quote
Old 02-04-2010, 06:00 PM   #27
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
What type of sandpaper do you use to sand after primer is installed?
ryanh is offline   Reply With Quote
Old 02-04-2010, 06:25 PM   #28
no sanding is needed between primer and top coats
Old 02-04-2010, 06:31 PM   #29
I always scuff walls between coats with sanding pole and 120 grit. just me way
The older I get the better I was
Old 02-04-2010, 10:57 PM   #30
ryanh's Avatar
Rewards Points: 154
What about any paint drips or little spots that weren't sanded down far enough, you able to hit those with 120 grit ??
Painting house for first time - equipment & safety tomcon Painting 3 07-09-2009 06:25 PM
Painting fireplace & trim? bltwa Interior Decorating 4 03-08-2009 01:57 AM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
Time for Painting Second Coat Dougit Painting 1 01-27-2008 09:33 PM
