Old 10-21-2007, 08:52 AM   #1
18% Moisture Content
How does one determine the moisture content of wood before applying stain or paint. Instructions usually say wait for 3 dry days. Can one count on this as dry enough?
rjordan392 is offline   Reply With Quote
Old 10-21-2007, 12:37 PM   #2
poppameth
Guest
Posts: n/a
Usually that's plenty but it can all depend on temperature and humidity. The only way to tell for sure is to get a moisture meter. You can usually get one for about $20 that is good enough for this purpose.
Old 10-21-2007, 02:37 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
18%-19% moisture content is what you have with kiln-dried lumber, but not pressure-treated or green lumber that have not been kiln-dried.
If you're priming and painting new lumber, I would get a moisture meter. Even kiln-dried lumber will absorb high humidity.
As you know, lumber that has too much moisture will bubble and peel your primer and paint in short order. The meter is well worth it to avoid such problems.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-21-2007, 02:55 PM   #4
Thanks,
It would be well worth it as I will be using Sikkens solid color stain.
I'll check the web for moisture meters.
Old 10-21-2007, 07:39 PM   #5
Tired, Cold, and Damp
slickshift's Avatar
I use a moisture meter
Your local Paint Store or Contractor Supply or Lumberyard should have the $35 one
slickshift is offline   Reply With Quote
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 10:48 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
Plan for solving basement moisture problem krx Remodeling 1 12-04-2005 08:00 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
Moisture and Mold problem Vin HVAC 1 02-24-2005 06:50 PM
