100 Year Old Walls With "personality" - Painting - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 03:02 PM   #1
100 year old walls with "personality"
I live in a 100 year old house with plaster walls in most rooms. You can see where bad patch jobs and bad paint jobs have been done over the past century. In at least 2 room, you can see where they glopped the paint on and had drops running down the wall that they let dry there. There are several spackel smears where they just didn't spend the time to get it even. They are harder to notice when flat paint is used in pastel colors. The kitchen is the worst. I would like to start over, but I don't know if that is a good idea, since there is most likely a few good layers of lead paint in the mix.
Is there anything I can use to level the wall that would look good and be a decent lasting fix for this?
mfhess is offline   Reply With Quote
Old 07-24-2011, 04:59 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
This might be more than a DIY fix- First off, there is probably lead paint in the mix, so dust containment is important.
If I had the job, I'd set up containment- then I'd screw the cracks with sheetrock screws to fasten then to the lathe, screen tape, a coat of hot mud to set, 2 coats of premixed also skimming out drips runs and errors- most likley skimming entire walls. Then sand smooth, prime, and paint.
Rinse and repeat on wherever needed.
Clean up contained area VERY thoroughly-
good luck- I've done many like this- it's a bit of work-
Brushjockey is offline   Reply With Quote
Old 07-24-2011, 05:04 PM   #3
Learning by Doing
Leah Frances's Avatar
Skim coat. Search this term on the site and you'll get lots of great advice.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-24-2011, 05:16 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
just a little
Old 07-24-2011, 05:36 PM   #5
Thanks so much
Old 07-24-2011, 08:18 PM   #6
The thing about 100 year old plaster walls is that they have character. I had a guy who worked for me, bit of a spackle zealot. He skimmed the walls of a 150 year old kitchen. Before I saw them, I got an irate call from the customer griping that he spackled the character off the walls. And he surely did. Cost me a few bucks. Sand out as much as you can and be selective with your tool (that can go a number of ways). Skim only those areas that are obvious man made screw ups and wear and tear damage, leave the character in place.
Old 07-24-2011, 08:28 PM   #7
Learning by Doing
don't kill too much TIME or too much Character by doing too good a job.
Old 07-25-2011, 04:35 AM   #8
chrisn's Avatar
Rewards Points: 312
We will not go there.
Old 07-25-2011, 06:49 AM   #9
I think that was a fairly unique client, JS. I have skimmed probably hundreds of walls in old plaster homes and all I've got was - wow! We thought we were stuck with the cracks and crap.
I have offered to use the cracks as part of a marbling effect, but as yet no one has bit on that.
Old 07-25-2011, 08:34 PM   #10
Nah brush, he had the walls looking pretty damn new. While not a plasterer, that's what his work was closer to than a drywall finisher. He floated those walls out. I couldn't get him to grasp the concept of three thin coats, light sand. He just had a tendency to apply it too heavily. I couldn't blame the customer. And he also realized what he did and apologized. Unfortunately, it was me who bore the cost. Don't get me wrong, he could do some real nice work with blades but sometimes he just went overboard.
Old 07-25-2011, 09:23 PM   #11
OK- Here's another little trick with skimming old plaster. It has "waves" that run horizontally with the lathe. If you skim horizontal, you will fill in the low spots of those waves. Sometimes it can be pretty dramatic the degree it does this.
5 year old condo - walls have a sour smell? jackie_thompsen Painting 10 05-23-2012 04:59 PM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Air-sealing attic at masonry walls jackbird Building & Construction 2 09-26-2010 10:38 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Straightening Racked Walls smitty286 Building & Construction 3 03-11-2008 08:35 AM
